Sony 1272 AKB Line
luk360
Posted: Tue Sep 08, 2020 5:53 pm    Post subject: Sony 1272 AKB Line
Hello all together, i am new in this Forum. I have 2 Sony Projectors, a 1272 and a 1292. I got them for free a while ago Smile. I've been wishing for one for a while and got lucky. I had 2 CRT Projector a long time ago. I have the 1272 installed on the ceiling.
I have a question about the AKB Line. If i go on the corners of the Phosphor the AKB Line will go over the Phosphor because it is more wide as the Picture itself.
Is this a problem for the Tube? does the AKB Line generate heat on the Tube? I have been looking everywhere but did not find a straight answer.
Maybe a Sony owner can tell me whether he leaves the AKB Line on the Phosphor or let it go outside?
- Lukas
Posted: Wed Sep 09, 2020 12:54 pm    Post subject:
Hi Lukas,
Welcome to the forum! I don't have an answer for you (having never owned a Sony myself) but over the last ~15 years it's definitely a topic that's been discussed dozens of times, so if nobody answers here you can use the search feature and read more.
Here are some hits after a quick search of "AKB":
http://www.curtpalme.com/forum/viewtopic.php?p=239950
http://www.curtpalme.com/forum/viewtopic.php?p=121009
http://www.curtpalme.com/forum/viewtopic.php?p=295952
http://www.curtpalme.com/forum/viewtopic.php?p=233362
http://www.curtpalme.com/forum/viewtopic.php?p=172735
http://www.curtpalme.com/forum/viewtopic.php?p=74618
https://www.curtpalme.com/forum_archived/viewtopic.php@t=10881.html
https://www.curtpalme.com/forum_archived/viewtopic.php@t=19835.html
You may want to also watch this free video on CRT projector setup as it's based around the 1292 and covers AKB:
http://www.curtpalme.com/SetupDVD.shtm
Good luck!
Posted: Wed Sep 09, 2020 2:06 pm    Post subject:
You're fine, it's not bright enough to damage the tube.
luk360
Posted: Wed Sep 09, 2020 6:56 pm    Post subject:
Thank you kal and Curt for your help!
