Any PC Gamers Out There?
Goto page 1, 2, 3, 4  Next
Phil Smith
Posted: Tue Sep 01, 2020 6:34 pm    Post subject: Any PC Gamers Out There?
My 10 year old grandson is into video games. So I bring a gaming PC home from the pawn shop. I know nothing about gaming PCs but it has a window on the side and I can see a video card with a fan on it. So I assume, cool, this should handle most games.
Not! In fact not even close. My grandson tries to play Fortnite and it's really laggy. We watch a video about optimizing a PC for Fortnite and we get it playing good! But soon the fans start ramping up and end up cranked. It's getting really hot. I look at Task Manager and the CPU is over 90% and the video card is over 90% as well. I don't why it plays so well with those kind of numbers but it does. But I don't want to burn it up so I close Fortnite.
I always thought gamers spent so much on their PCs to get an advantage over other players. Now it seems, to a certain degree, it's required just to play PC games. I had no idea.
It's not like it's a terrible computer. A long ways from good one, but it seems like it should at least be able to play games at a decent level. Here's what I have:
AMD A10-5800B 3.8GHz FM2 socket 2 cores processor
Radeon RX 560 4GB graphics card
ASRock FM2A88X Pro3+ motherboard FM2+ socket
16GB DDR3 RAM
Should I forget this PC and look for a different one? Or is there hope for it.
Posted: Tue Sep 01, 2020 7:09 pm    Post subject:
That's an 8 year old processor and a 3 year old video card so 90% makes sense.
Posted: Tue Sep 01, 2020 8:02 pm    Post subject:
The top games all push the latest/fastest hardware to the max. I'm surprised you got it working well at all. I doubt you would burn anything up, assuming it's got proper fans &etc. I'd keep an eye on the temps though.
Phil Smith
Posted: Tue Sep 01, 2020 8:16 pm    Post subject:
Thanks for the responses.
That I always assumed was the reason for the mega dollar gaming rigs, Gary. What I didn't know is you had to have a pretty decent PC just to play PC games at all.
So you don't think it will toast itself? It has 3 large case fans but a smallish CPU fan. Maybe get a good CPU fan and hope for the best?
From what I've read it seems I'd have to spend at least $600 to get something that will play Fortnite. I'd like my grandson to have some PC experience but I don't know about spending that much on one.
Phil Smith
Posted: Tue Sep 01, 2020 8:35 pm    Post subject:
Jeremy, here's a list of FM2/FM2+ socket CPUs that my MB should support. Mine is pretty low on that list. Will a higher rated CPU help my situation?
https://www.cpubenchmark.net/socketType.html#i16
Posted: Tue Sep 01, 2020 10:25 pm    Post subject:
More importantly what processores does the motherboard support:
https://www.asrock.com/mb/AMD/FM2A88X%20Pro3+/#CPU
Yours is an A10 which means it has built in graphics on the CPU. 4 MB Radeon HD 7660D, also it's a 4 core 3800MHz with a single core turbo of 4200MHz.
I have the 4100MHz version at the office.
To upgrade this system I would go with an Athlon X4 AD880KXBI44JC 4000MHz, 2x2MB L2 cache and a bigger CPU cooler.
Other than that or replacing the video card there's not much upgrading to be done.
Alternativly just do the CPU heatsink and fan then use it as is.
The other thing you can do it play older games. Goto GOG.com and check out more period correct games say 2005-2013ish that will run better on that system. You can also hit thrift stores for CD-ROM and DVD-ROM coppies or, you know, a local pawn shop. Very Happy
Posted: Tue Sep 01, 2020 10:47 pm    Post subject:
Jeremy, isn't the GPU more likely the bottleneck? I have no idea how CPU-intensive current games are, but I know they put a lot of load on the graphics processor. But most games can be throttled back (less graphic effects) so it's not quite so photo-realistic, and that takes much less GPU power.
Posted: Tue Sep 01, 2020 11:06 pm    Post subject:
Yeah, as I mentioned. He can upgrade the video card but, seeing as his is 'only' 3 years old and the processor is a business class econo job I would recommend a snapier processor. If he did both a processor AND a graphics card then it would really wake up that old system. Have to make sure there's enough power supply for the video card too.
On older less capable cards you can go into the game settings and turn off/down graphic settings to make it run better. You are correct.
Phil Smith
Posted: Wed Sep 02, 2020 1:20 am    Post subject:
Jeremy that CPU doesn't look to be much of an improvement.
https://cpu.userbenchmark.com/Compare/AMD-Athlon-X4-880K-vs-AMD-A10-5800K-APU-2012-DTr/m121029vs2007
I can't find one anyway, which is the case with a lot of the FM2 CPUs. Long outdated I guess.
One of the things we did to improve performance was to turn video card setting *up*! The CPU was running at plus 90% and the video card at ~ 35%. That was suppose to throw some of work load on to the video card, which it seemed to do and it did make performance better. But CPU usage didn't go down for some reason. Now instead of one being maxed out they're both maxed out.
I think I'm going to blow this project off. I've been effing with it for 3 days with no improvement in site. That's enough time wasted.
Posted: Wed Sep 02, 2020 1:34 am    Post subject:
$100 ebay. it has faster memory support. EDIT: so depending on the speed of your 16gb RAM you could eek out a little more speed.
Just grab a bigger CPU cooler and use the PC as is.
As for 3 days. it took me 30 days, 8-10 hours per day to get my GForce 4600 card running right back in 2003. Good times.
Posted: Wed Sep 02, 2020 2:01 am    Post subject:
The term "Gaming PC" can mean whatever you want it to be. Some companies realize that people have no idea what they're doing so they slap a 50 cent plastic window on the case with a few LED lights and market it as such. Walmart seems to get this: https://www.youtube.com/watch?v=VWHlPH23P-w
You can buy a "gaming pc" for $200-300, and you can also spend $5000+. All depends on what you're after, no different than buying a car. But just like buying a 1972 Yugo with a spoiler on it doesn't make it a race car, a plastic window and some lights on a PC case doesn't make it a gaming PC. Wink
The PC you have Phil was probably from some years ago and was probably low end for gaming to begin with. That doesn't mean it can't be used for gaming, especially for a 10 year old who probably has somewhat low expectations anyway. He’s not going to notice the difference between anisotropic filter off and at 16x. Wink
I would just turn the game settings down and use it "as is". Fortnite isn't overly taxing with settings turned down, especially if you go 1080p or lower. Gaming PCs components (mostly the GPU) start to get really expensive if you expect 60+ FPS at 4K.
Posted: Wed Sep 02, 2020 3:03 am    Post subject:
My 2nd gaming PC 1999-2003, $20 000. Sooo much fun!
Phil Smith
Posted: Wed Sep 02, 2020 3:07 am    Post subject:
Jeremy I saw that on ebay. Those are used from China, which seems kind of odd. Not comfortable buying that.
I paid $100 for the whole PC with gaming headphones. It has one of those cases with 3 color change fans you were talking about. My grandson loves it. I can sell it at the shop for at least $200. I'll just go that route.
Kal, I've built a lot of computers. Just never been a gamer and know nothing about them. I built 2 HTPCs back in the day which I overclocked to get decent ripped DVD playback. Spent a fair amount of money on both of those. I had pricey video cards in them. I guess they were basically gaming PCs.
I spent at least a couple of grand, probably 3, on this DAW. It's old and not worth much these days. An old 4 core i7, 32GB RAM, 2 or 3TB SSDs.
I haven't had it fully set up in 3-4 years. I might give it a try for gaming.
Also, my grandson has an i5 w/8GB RAM laptop he saved up for and bought from the pawn shop. It runs Fortnite just fine. I just wanted a full PC he could tinker with at my house.
Posted: Wed Sep 02, 2020 3:18 am    Post subject:
No, not gaming PCs. Gaming PCs have a disproportionate amount of funds that go just towards the graphics card (GPU) usually as that's where the action is. 50% of the cost is an often quoted amount but it will vary depending on the games you want to play. That's separate from anything not in the tower (monitor/keyboard/mouse/etc) not included.
HTPC has very little GPU requirements at all. Often the video card was dirt cheap. I build a few as well, and mod'ed the video cards various ways to bypass filters. The video cards were always a very inexpensive portion of the build.
I spent at least a couple of grand, probably 3, on this DAW. It's old and not worth much these days. An old 4 core i7, 32GB RAM, 2 or 3TB SSDs. I haven't had it fully set up in 3-4 years. I might give it a try for gaming.
Throw in a $300-500 video card and it'll likely be fairly good if 1080p gaming is all you need. If you want 4K, you're looking at $1000 or more just for the video card. Really depending on the games he plays and what resolution/refresh rate he expects. Given he's 10 and this is probably his first gaming PC (?), I'd say 1080p is more than adequate. Wink
The i7 won't help at all in most cases. i5 is fine for most games or even i3. If he gets into highly CPU intensive simulation games like Space Engineers, or possibly massive strategy games, things may change and a better CPU can help.
Again, the CPU and RAM are somewhat meaningless when gaming is concerned (within reason). It's all about the GPU in most cases. There are lots of YouTube videos showing fairly high end (graphically speaking) games being played on various CPUs from i3s to i7s showing fairly similar refresh rates. Same with RAM: 8Gb most of the time is all you need and more won't give you faster frame rates, though I've typically always put in 16 just because it's reasonably cheap.
Posted: Wed Sep 02, 2020 3:22 am    Post subject:
Things were definitely crazier back then. I remember in the mid 90s spending $1500 for a CPU.
Posted: Wed Sep 02, 2020 4:04 am    Post subject:
Yeah my 128meg 4600 video card was $850 in 2002
Posted: Wed Sep 02, 2020 12:45 pm    Post subject:
In case you haven't seen it Phil, a great website for PC parts pricing and to ensure parts work together: https://pcpartpicker.com/
Phil Smith
Posted: Wed Sep 02, 2020 10:14 pm    Post subject:
Kal, yes gaming PCs I would say. Like you and Jeremy build? No, but they both had fairly pricey MBs that could be overclocked and came with overclocking software for the MB and CPU. At least one of them had a heat pipe on the chipset chip. The $180 NVidia cards had big heat sinks on them and I think fans as well.
Well I couldn't leave it alone. Last night after some more tweeking I got Fortnite playing well. Surprisingly well. And with no heat issues. Then it really went to hell. Fortnite wouldn't load right. That got worse until Fortnite wouldn't play at all. Nothing would fix it.
But I was encouraged. I had removed Fortnite and updated Windows on Monday. The PC never has auto- restarted. It boots down and hangs on a blank screen, or shuts off entirely. That might have screwed up the update process. There were some odd problems with windoes after updating.
I wanted to eliminate that as a possible source of my problem. So I check update and there's still updates to be loaded. I download them and they won't run! I try some fixes from MS's website to no avail. So after hours of fighting that, I decide to try the windows repair option. That seems to be working (it's doing it as I type) but as far as I can tell it downloaded the updates again! That's 3 times in 3 days. And each time takes a long time. Frustrating!
I would have been better off if I hadn't got it to briefly play well last night. I wouldn't have spent yet another day on this. And who knows if any of this is going to work.
PS: This is a possible reason it not auto-restarting. At least I hope it is. I can't try it until it completes the repair process.
https://www.tenforums.com/general-support/19805-windows-10-wont-do-restart.html
Posted: Fri Sep 04, 2020 12:34 am    Post subject:
Ahhh Windows 10. I am so glad I never went down THAT rabit hole.
Phil Smith
Posted: Fri Sep 04, 2020 5:02 am    Post subject:
I spent almost all day Wednesday working on it but finally got everything sorted out. Thumbs Up
More tweaking (lots of youtube videos on the subject) and I got Fortnite running pretty good. Not perfect but decent.
So I can't do much about my CPU without changing the motherboard, which will probably require new RAM as well. I don't want to do that. You guys say the video card matters most. What about upgrading that?
All I need to run is 1080 @ 60Hz. That's what my 80" TV is. This page ranks video cards by what resolution and refresh rate they'll run. Would I benefit form any of these? They are listed as the minimum required to run what I need.
https://www.logicalincrements.com/articles/graphicscardcomparison
50%
GTX 1060 6GB
GTX 690
GTX 1060 3GB
GTX 780 Ti
50%
RX 5500 XT
RX 580
RX 480 8GB
RX 480 4GB
R9 390X
Xbox One X GPU
45%
GTX TITAN (Kepler, 2013)
GTX 970
45%
R9 390
R9 290X
RX 570
40%
GTX 1650
40%
R9 290
RX 470
35%
GTX 780
GTX 590
35%
R9 380X
R9 280X
HD 7970 GHz
Page 1 of 4
