Barcographics 808 and scart
Fjellreven
Posted: Fri Aug 21, 2020 5:45 pm    Post subject: Barcographics 808 and scart
Hello i have noticed that the barcographics 808 has rgbs input which is also on scart. Can you use a scart rgbs to bnc rgbs adapter. I know the wiring is the same but i am not sure the signal is the same.
Boet
Posted: Sat Aug 29, 2020 11:23 am    Post subject:
Yes, I've hooked up an 8 bit gaming console via its scart RGBS outputs to a Barco 701s.
Depending on the signals from the source, you may need to try whether composite video or separate sync gives you the best sync into the S port.
Zebra
Posted: Sun Sep 06, 2020 11:44 pm    Post subject:
Get one with a built in sync strike. RGB scart cables from consoles sync on composite video. Some monitors and interfaces require clean sync to work, others don't. A scart to BNC adapter with a built in sync separater usually gives me less problems.
I've had the best results with this one:
https://www.ebay.com/itm/Female-RGB-Euro-SCART-to-4-BNC-Audio-Cable-BUILT-IN-SYNC-STRIPPER-XM29-PVM-BVM/193370929834?hash=item2d05ce3aaa:g:IOwAAOSwPhdU47vv&mkcid=1&mkrid=711-53200-19255-0&siteid=0&campid=5336656890&toolid=20008&mkevt=1
