| Posted: Sun Mar 01, 2020 5:53 am Post subject: |
8000 lbs of viewing goodness
| Posted: Mon Mar 02, 2020 5:35 pm Post subject: |
sucks they will be scrapped. if they're flight sim's then trapezoid tube wear on all of them except maybe a handful of tubes that were replaced prior to decommission. So you'd be buying 2tons of 9500's to maybe get one or 2 good machines by moving tubes around.
thehockeytowner
| Posted: Fri May 08, 2020 2:58 am Post subject: |
These are on the big auction site now -- or at least they're reusing the photos. The asking price is, IMO as a novice, high. But the other huge lot of 9500LCs has an asking price that is certifiably insane.
_________________ Go Wings!
kal Forum Administrator
| Posted: Fri May 08, 2020 12:54 pm Post subject: |
| draganm wrote: | | sucks they will be scrapped. if they're flight sim's then trapezoid tube wear on all of them except maybe a handful of tubes that were replaced prior to decommission. So you'd be buying 2tons of 9500's to maybe get one or 2 good machines by moving tubes around. |
+1
With this many they'd typically have a spare or two as well (just in case) so you'd be buying the lot hoping for that one or two machines that will be usuable.
You'd certainly get a lot of spare parts and boards however. Where you'd store all these or how you'd move them is a whole other issue. Not like you could sell the ones with oddball tube wear as nobody wants this stuff. (Hence the reason it's $1000 for 20 units). IMHO you're better off spending the $1000 on a used JVC LCOS projector if it's for HT use.
