Sony VPH-D50 convergence / tube alignment
faxesystem
Posted: Tue Dec 24, 2019 9:45 pm    Post subject: Sony VPH-D50 convergence / tube alignment
Hi, I got my hands on a VPH-D50 and played around with it last night. I've read the setup guide but I can't get the blue tube aligned as described in the manual. I found something about manual toe in that has to be done on CRT projectors but sadly I can't find any information on how to do that on a VPH-D50.
When trying to align the lines via the menu I can't get the blue line low enough. Also I don't have a remote.
So is there a way to manually adjust the tube alignment?
Thank you for your help.
Posted: Tue Dec 24, 2019 11:27 pm    Post subject:
Yes, use Zone 1 in the convergence menu (middle zone), which is the coarse raster shift for all tubes. Toe-in is only for left-right movement, not vertical shift.
Sony doesn't make any of this clear in their otherwise excellent manual, I was answering this question at least 3 x a week back in the day. Smile
Posted: Tue Dec 24, 2019 11:34 pm    Post subject:
You can't do much on a D50 without a remote. Find one of those. Same one for the G70 and G90 FYI
faxesystem
Posted: Wed Dec 25, 2019 5:51 am    Post subject:
Thank you for your answers and happy holidays. Regarding not having a remote. When activating the serviceman mode I can see all the nice options but I can't select any of them. It just says "GUIDE" on the right side and is not showing any sub menus or options. I assume that's what I need the remote for?
Posted: Wed Dec 25, 2019 10:42 pm    Post subject:
Yes. It's the only SONY I notice that doesn't have a remote/control panel built in.
faxesystem
Posted: Wed Dec 25, 2019 10:52 pm    Post subject:
Thank you. I already downloaded IRScrutinizer and got me the IR codes for the RM-PJ1000. I exported them to .asmr format and imported them into the android app "AnyMote - Smart Remote". I always kept a cheap Android smartphone with an IR sensor for such occasions. I'll try it at the weekend. Smile
Posted: Thu Dec 26, 2019 7:17 am    Post subject:
Then remember this key sequence: ENTER,ENTER, ARROW UP, ARROW DOWN, ENTER. This gets you into ""Serviceman" mode
