Marquee Projector: anyone using RS232 to control it?
nidi
Posted: Tue Nov 12, 2019 6:31 pm    Post subject: Marquee Projector: anyone using RS232 to control it?
A friend of mine is trying to include his Marquee in the RTI control system.
is anyone out there that controls his Marquee via RS 232 ?
barclay66
Posted: Wed Nov 13, 2019 9:45 am    Post subject:
Normally, I would use the remote only. But once I made a presentation using my test machine and as I had forgotten all of the remotes, I did have to use a PC with the serial cable. I used the Marquee Control Program and it worked pretty well. So there shouldn’t be any problems as long as the settings are correct and if You use the right command codes.
The codes are described in the Tech Bulletins TB96-05 and TB97-01 available in the manuals section here.
Kind Regards
barclay66
nidi
Posted: Wed Nov 13, 2019 6:36 pm    Post subject:
Kind Regards
barclay66
Thanks Barclay66,
when commands are sent via RS232, is the OSD visible?
the codes are known and sent to the programmer of the driver for controlling the Marquee
via the RTI system.
the feedback from the commands to the Marquee are needed for the RTI remote control to
sense if they have been executed.
Posted: Fri Nov 15, 2019 3:08 pm    Post subject:
Guys
There is a setting somewhere in Preferences for turning OSD off, business presenters liked that.
nidi
Posted: Sat Nov 16, 2019 6:51 pm    Post subject:
Tim in Phoenix wrote:
Guys
Tim,
can't find it in my preferences menu.
I have following points:
1. Auto power Off
2. -
3. Blanking Time
4. Cannel Select
5. -
6. Programmable Events
Posted: Sat Nov 16, 2019 10:55 pm    Post subject:
Say Nidi
Let me check, I'll get back to you Sunday.
Posted: Sat Nov 16, 2019 11:09 pm    Post subject:
Hello
Try UTILS, 5 is PREFS, 2 is Screen Messages ON/OFF
If I remember correctly, when Screen Messages are off and you want to see one, press Recall, Contrast for example, and it will be shown for that function one time.
