Video chain on G90?
deronmoped
Posted: Sun Mar 10, 2019 2:26 am    Post subject: Video chain on G90?
So I was wondering, does it matter if I feed my G90 with a digital signal or a analog one? I'm using a HTPC so I have a choice of DVI with a HDMI adapter to the HDMI input and a VGA to RGBHV input. Does the G90 change the digital signal to analog or does it change a analog signal to digital? Visually is there any difference?
Posted: Sun Mar 10, 2019 4:54 am    Post subject:
All CRTs change a digital signal to analog, the difference is whether you do it in the computer, or in the Moome card.
wanderer
Posted: Sun Mar 10, 2019 7:59 am    Post subject:
Hi Deron, try both the DVI\HDMI and then direct VGA and see which one looks better. One or the other will look better, owing to one having a better signal path, less bandwidth loss, etc. You won't know though until you test it all out Smile
gregstv
Posted: Mon Mar 11, 2019 2:35 am    Post subject:
Pictures of your testing please.
Posted: Mon Mar 11, 2019 1:57 pm    Post subject:
All things being equal, staying digital as long as possible is the best solution as the signal is impervious to change while digital, or should I say, it's either the same (correct) or it isn't (incorrect). If it's changed then that's an error and given the nature of HDMI signals often you'll get no pic at all. Analog signals on the other hand degrade over any path, be it 1000km or 2cm. That's just the nature of analog. Whether that change is noticeable is the unknown.
Now things are never equal. So if you had all digital to the projector and then a REALLY crappy digital to analog converter directly installed in the CRT projector, that may look worse than having a really good digital to analog converter near the source device and then pushing that signal over a long analog cable to the projector.
The good news is that you have a Sony CRT projector and Moome's Sony HDMI input cards are very good at converting HDMI to analog: http://www.curtpalme.com/IFB-FULLHD.shtm
tfuller
Posted: Tue Mar 12, 2019 1:19 am    Post subject:
Another significant advantage is that running all your inputs through a single digital converter reduces the amount of setup you have to do for every source, even more so if they all use the same resolution
deronmoped
Posted: Wed Mar 13, 2019 1:32 am    Post subject:
I have a HDMI card in the G90, is that something Sony installed or could it be aftermarket?
Posted: Wed Mar 13, 2019 12:15 pm    Post subject:
If you have an HDMI card in your G90 it would be Moome's IFB-FULLHD v3: HDMI 1.4 Input Card with 3D card here (or an earlier version): http://www.curtpalme.com/IFB-FULLHD.shtm
Nobody else makes HDMI cards for the G90. Sony never did either. The G90 was designed/built about 5-6 years before HDMI even existed.
deronmoped
Posted: Tue Mar 19, 2019 2:23 am    Post subject:
Yeah, I have the early version card with one HDMI input and component input.
Posted: Tue Mar 19, 2019 2:54 am    Post subject:
Component? That's one of the really old ones! You may want consider the newest version - it's about 4 generations newer with improved image quality all around: http://www.curtpalme.com/IFB-FULLHD.shtm
HaydnG90
Posted: Tue Mar 19, 2019 4:34 am    Post subject:
And also better/more reliable HDCP handshake.
Posted: Tue Mar 26, 2019 3:06 pm    Post subject:
That card is terrible. It has horrible bandwidth limitations. With that card your PC analog will almost certainly be better.
Like Kal, I would suggest one of the newer Moome cards. The current card or the one before it are both great (you can tell which cards are the good ones because they are the only versions with two HDMI inputs). I have several of the older of the two that I am going to list if you decide not to go with one of the newest cards.
Best,
deronmoped
Posted: Thu Mar 28, 2019 4:13 am    Post subject:
I have not had much time to work with setting up the PJ, so it's going to be a while before I have all the convergence and focus done. Then I will be able to evaluate the analog to see if I will be happy with that or get a better HDMI card.
gregstv
Posted: Sat Mar 30, 2019 6:20 am    Post subject:
Is Moome still selling internal cards?
