R7625189 versus R762518
Posted: Mon Jan 28, 2019 9:10 am    Post subject: R7625189 versus R762518
Does anyone know if there is actually any difference between these two boards?
The R7625189 is (according to documentation) from an 812 but I have unknowingly been using it in my 809 as it looks identical to the R762518.
Posted: Mon Jan 28, 2019 3:05 pm    Post subject:
The 7th digit is usually some minor mod or revision to first 6 digits of the board number. So a 762106 power supply is an older version of a 7621065, but they will interchange. Not sure in your case what the mod is, but yes, it should work fine.
robin36mac
Posted: Mon Jan 28, 2019 5:07 pm    Post subject:
Hello,
They seem to use even the same PCB number, so they should be damn close...
Robin
Hulio
Posted: Mon Jan 28, 2019 11:21 pm    Post subject:
Yep, you are ok. If additional digit is 5,7 or 9, it means fully compatible. From 1 till 4 not compatible.
Posted: Tue Jan 29, 2019 5:35 am    Post subject:
Thanks everyone.
Posted: Tue Jan 29, 2019 7:09 am    Post subject:
km987654 wrote:
Thanks everyone.
What are you franken-building over there Keith?
Posted: Tue Jan 29, 2019 7:32 am    Post subject:
km987654 wrote:
Thanks everyone.
You know me a bit of this PJ and bit of that PJ. My Frankin-PJ throws a mighty picture Thumbs Up
