Vertical noise on picture
Meemil
Posted: Fri Dec 21, 2018 3:26 pm    Post subject: Vertical noise on picture
Hey,
I jusy today noticed small vertical lines running thru the picture. They're most noticeable on external signal, and more so with high bandwidth ones (eg. 1080p 72hz). I spent the whole day diagnosing the problem and found out that removing the stig amp wires fixes it. I tried a swap stig amp but without luck.
This seems just bizarre, what could be the next place to look for?
Update:
Taking out the focus wires while SAB is connected fixes it too!
Update 2:
Dang I keep editing this lol. But it seems that taking any tube out of either SAB or FGM fixes it. I've tried swapping the wires all the way from VDM to SAB and FGM. Seems like there is no clear pattern to this, which doesn't indicate a board problem.
Posted: Fri Dec 21, 2018 7:42 pm    Post subject:
There is a grounding problem with the astig amplifier, do a search on the forum. Adding extra grounding should eliminate this noise.
Meemil
Posted: Fri Dec 28, 2018 12:29 am    Post subject:
Thanks Gjaky that did the trick! Did some research and the output is now way clearer after bunch of ground bridges to different boards.
