larryp
Joined: 24 Jan 2012 Posts: 252 Location: eden prairie mn
| Posted: Tue Oct 16, 2018 10:35 pm Post subject: No Video |
I have a Sony 1272, Sony switcher with a Mony card and I use a Denon AVR X1200W receiver for my HDMI connections.
Today I turn everything on and I can't get any video.
I get sound, but no video. Projector seems fine.
I unplugged everything, reset what I could but still no video from any source.
Can something in the receiver go out making this happen?
HaydnG90
| Posted: Tue Oct 16, 2018 10:46 pm Post subject: |
Do you see menus?
Try connecting source direct to pj bypassing receiver to see if thats the issue.
HDMI cables have been known to go bad? Might be worth trying another cable.
tfuller
| Posted: Wed Oct 17, 2018 12:19 am Post subject: |
Make sure the projector is powered on and the correct input selected before powering on your HDMI source. The HDCP handshake apparently needs to happen with the input card ready when the source powers on.
HaydnG90
| Posted: Wed Oct 17, 2018 1:04 am Post subject: |
Good point. Not sure which version Moome you have but the earlier ones did have handshake issues.
| Posted: Wed Oct 17, 2018 2:23 pm Post subject: |
Connect a bluray player with a short 6' HDMI cable right to the input of the Moome card. See if that works. The HDMI switches on all receivers can die for no reason at any time, that seems to be the most common problem with the current AV receivers.
| Posted: Wed Oct 17, 2018 3:26 pm Post subject: |
Lovely. I have an ooold pre-HDMI receiver that works fine for everything except switching HDMI. I occasionally consider replacing it with a new one so the receiver can switch audio and video together over HDMI. But if the HDMI switch is likely to die quickly, that makes it a not-very-attractive option.
kal Forum Administrator
larryp
| Posted: Wed Oct 17, 2018 6:49 pm Post subject: |
I reset everything, put a new hdmi cable in from the moomie card to the receiver. Still no video input on any source. Projector screens come up fine.
Does the receiver have a hdmi setting? Maybe i pressed something on the remote I shouldn't of??
larryp
| Posted: Wed Oct 17, 2018 7:04 pm Post subject: |
I plugged the hdmi cable from the blueray into the moomie card. same results, no input signal
HaydnG90
| Posted: Wed Oct 17, 2018 7:47 pm Post subject: |
Sounds like a pj issue then. Have you reseated the Moome? What if you go RGBHV and bypass the Moome. Probably the card.
larryp
| Posted: Wed Oct 17, 2018 8:46 pm Post subject: |
This is really weird. I hooked up my monitor to the receiver to check all the settings. I need the monitor to see the set up menu.
Everything looked fine, didn't change a thing.
Plugged the cable back into the Moomie card and all of a sudden I got my video back! lol
No idea why or what happened. Really bizarre
THANK YOU to everyone who replied.
