stuck scheimpflug adjustment
jaredjaric
Posted: Wed Jul 25, 2018 4:59 pm    Post subject: stuck scheimpflug adjustment
Hope the masters can help me on this .
And so the 909 is running well, with the old smps and newly replaced standby board. I suddenly fet the urge to tweak the focus , both electronically and mechanically, thus the scheimpflug adjustment.
On the red tube , with B1 to B2 loosened ,one of the scheimpflug adjustment seems stuck.
Peering inside the crt , i can see that the cam lobe is not turning, when adjusting scheimpflug.
How do i fix the cam without pulling out the crt tube?
Posted: Thu Jul 26, 2018 1:59 am    Post subject:
Pull out the tube, it's the right way to do it. You'll mos likely break the magnet assembly if you try to mess with it while on the tube.
