Krepticor
| Posted: Sat Jul 14, 2018 5:18 am Post subject: runco vfc-4400 |
does anyone have Anymore info on this line doubler/tripler/quadrupler?
kal Forum Administrator
| Posted: Sat Jul 14, 2018 4:06 pm Post subject: |
I've worked on a few of them back in the day. Not really good units, even 10 years ago, and worthless at this point. Probably about $20K when new though.
| Posted: Sat Jul 14, 2018 10:23 pm Post subject: |
BTW, if you need a low cost scaler, look for a used Lumagen or Faroudja. Far better and more reliable than the Runco. A bunch of the Runcos suffered from bad caps, causing low output, color shift, etc.
Krepticor
| Posted: Sat Jul 14, 2018 11:17 pm Post subject: |
well I found one cheap and wanted a line doubler/quadrupler for converting old rgbs output videogames prior to a scaler, issue is I know the output on most of those is actually 240p
my issue is I do not seem to be getting video from the runco
I dont have my projector setup just yet, so I can't wire it up to that just yet, just testing for functionality at this point
| Posted: Sun Jul 15, 2018 3:00 pm Post subject: |
No scaler save perhaps for a Lumagen will convert an RGBS signal to anything. If the Runco has a VGA input, it's simply a passthrough connection from that VGA connector to the 5 BNC outputs.
You should be able to take the RGBS output and connect it directly to your projector RGBHV input. If you use the RGBH inputs, that's equal to RGBS.
| Posted: Sun Jul 15, 2018 3:54 pm Post subject: |
Why not run 240p on the projector? Scan lines 6 feet high!
nidi
| Posted: Sat Apr 20, 2019 9:17 am Post subject: |
anything you need to know about retrogame video formats and best processors can be found here:
http://retrogaming.hazard-city.de/
hope that helps
Michael
