G90 standby power-supply question
Apfelmousse
Posted: Sun Jun 17, 2018 6:42 pm    Post subject: G90 standby power-supply question
Hi all,
when I had my Barco 808, I pulled some mA of standby power from the remote-control port to illuminate some LEDs.
Now I'm wondering if I can do the same with the G90. Studying the service manaual back-and-forth it seems there is no off-the-shelf possibilty with the available ports. There's 12V on the Trigger port, but with a high resistance in series and only when the projector is running.
There should be a standby power rail somewhere where I could eventually grab that voltage (probably a 12V rail). But I can't figure out where.
Anybody who can give me a hint? Thanks!
cheers
Martin
barclay66
Posted: Sun Jun 17, 2018 8:02 pm    Post subject:
Look for the SUB6V generated on the GB board. This should be present at Stand-by as it powers the infrared receiver. Otherwise, use the SUB6V or the 12V from the trigger output for switching an external power supply using a solid state relay.
You could use something like this: https://www.pollin.de/p/solid-state-relais-ssr-d32a380-5-3-32-v-5-a-380-v-340633
Kind Regards,
barclay66
