Barco Input Card max resolution
Corleone88
Posted: Mon Apr 23, 2018 3:24 pm    Post subject: Barco Input Card max resolution
Hello,
Is it possible to do more than 1080p on the last version of the Moome Barco Input HDMI card? Anyone tried this for example 1440p at 60Hz?
Corleone88
Posted: Tue Apr 24, 2018 9:05 am    Post subject:
What is the maximum bandwidth?
Hulio
Posted: Tue Apr 24, 2018 10:29 am    Post subject:
Bandwidth wise, it seems to be more than a CRT projector is capable of (250 MHz). In practice, maybe lower...
As for max. resolution, 1440x960@72Hz in PC mode and 1920x1080P@75Hz in HDTV mode.
Posted: Tue Apr 24, 2018 11:59 am    Post subject:
Take a look at the manual on the order page: http://www.curtpalme.com/BARCO-FULLHD.shtm
It mentions 1920x1200 @ 75Hz is available (1200p)
What Barco do you have Corleone88? Anything above 1080p is hard to resolve properly even on a Cine 9.
Corleone88
Posted: Tue Apr 24, 2018 12:06 pm    Post subject:
I have a BG1209s but I am wondering if upgrading with Eisemann mods can resolve resolution above 1080p.
About the Barco HDMI card, if the bandwidth is 250MHz, the card could resolve more than 1200p 75Hz (=173MHz). The product specs usually show popular resolutions/frequencies like 1080p. If the chip has no predefined resolutions, it should be able to resolve better than 1080p at 75Hz, right? Or maybe I missed something Smile
Posted: Tue Apr 24, 2018 12:17 pm    Post subject:
I would email Moome and ask - probably the best way to find out exactly what can be done.
For what it's worth, I wouldn't both with trying to get more than 1080p out of a BG1209s, especially if you're running higher than 60Hz.
