Using ASR on a Marquee with a 3rd Party Switcher
UncleWill
Posted: Sat Mar 31, 2018 3:43 am    Post subject: Using ASR on a Marquee with a 3rd Party Switcher
Trying to figure this out. So my Marquee has one RGBHV input, connected to a Sony 1271 Switcher. Running four RGBHV sources into it.
As expected, all of them have require different settings. I never really learned to do ASR well.
Anybody have any tips? Looking at the Marquee manual now:
http://www.curtpalme.com/docs/ElectrohomeMarquee8500_User.pdf
UncleWill
Posted: Mon Apr 02, 2018 5:58 pm    Post subject:
Nothing? Sad
barclay66
Posted: Tue Apr 03, 2018 2:03 pm    Post subject:
I've never bothered using ASR. Instead, I've programmed all necessary resolutions and their settings into the channel list. All I need for a different source is to press the corresponding channel number on the remote.
Just like it's described over here: http://www.etechvideo.com/techarticle2.htm (scroll down for details).
Nice side-effect: Any kind of setting (e.g. Brightness, Contrast, Geometry and even Convergence) can be tied to a channel number!
Kind Regards,
barclay66
P.S.: On "Installment Four" You can read more about ASR/ASI and its usage (http://www.etechvideo.com/techarticle4.htm)
UncleWill
Posted: Sun Apr 15, 2018 2:29 pm    Post subject:
Just read the first link. So, how do I save a new configuration again?
barclay66
Posted: Tue Apr 17, 2018 7:17 am    Post subject:
First, check the list of the current recall memories (<UTIL>, <3>). It will show the input settings already stored. You can use <UTIL>, <1>, <1> for copying one of these to a formerly unused number and this will create a new one.
Or, feed the PJ a previously unknown signal and it should create a new recall memeory itself.
The recall memories can then be combined with an input selection into the channel list...
Regards,
barclay66
