Corleone88
| Posted: Fri Feb 23, 2018 8:36 pm Post subject: Black thin horizontal line |
Hello,
I have a thin horizontal black line in the middle of the red tube. Is there a way to remove this?
I saw this on a Lumagen test pattern
pj-toso
Joined: 19 Mar 2015 Posts: 69 Location: Norway - Oppland
| Posted: Fri Feb 23, 2018 8:52 pm Post subject: |
To much adjustments have been used. You have to set all adjustments to midpoint. Position and align the projector perfectly, then adjust the magnets on the tubes so the horizontal and vertical center lines are in their best position before starting adjustments.
_________________ Disclaimer: My postings are subjective and not facts.
Corleone88
| Posted: Sat Feb 24, 2018 8:26 am Post subject: |
Ok thanks
kal Forum Administrator
| Posted: Sat Feb 24, 2018 3:00 pm Post subject: |
It's called the "line of coincidence":
https://www.curtpalme.com/forum_archived/viewtopic.php@t=10082.html
https://www.curtpalme.com/forum_archived/viewtopic.php@t=12672.html
More:
Q: I have an odd horizontal line visible at times, what is it?
A: At times you may see a horizontal line that fades in the middle of the picture but it quite visible at one end (often the right side), it will be most visible on bright scenes, all white fields or light blues. This is called the horizontal line of coincidence, to some extent it's natural on some models of projector but careful adjustment can remove or at least minimise it. Pause a scene where the line is plainly visible, note which side it shows the most, go to a genlocked pattern and adjust horizontal skew to lower the horizontal centre line on the opposite side to the worst one. Do this by only a small amount, say 4-5 clicks. Now adjust top and bottom keystone to correct the error the skew change introduced. Go back to the picture, is the line less? If it's worse you skewed the wrong way, if it's better carry on tweaking the skew and keystone to minimise or remove the line. You may end up with a horizontal skew error that's plainly visible on the test pattern, it should not be obvious on actual video. Excessive use of horizontal bow may also make the line worse, again it should be possible to reduce the effect by adjusting horizontal bow and correcting the resulting top / bottom bow errors. Removing the line completely may not be possible but you should be able to reduce it to an acceptable level. The line is caused by the projector set-up making several scan line converge as they cross the tube face, result: one large visible scan line.
If deflection coil angles are set wrong or the projector is not mounted flat it will not be possible to remove the line. To check deflection coil angles check the projector is flat with a spirit level, check the screen is flat with a spirit level, sent horizontal skew to 49, delete convergence settings for that block (see this answer). Go to convergence and exactly centre red and blue on green using only the middle zone (actually raster shift). Now check the green horizontal line is parallel with the ground and that both red and blue exactly match green. If anything is wrong you have deflection coil angle problems. Correcting this will require all blocks to be deleted and the projector set to mid point in the service menu. At this point also check raster widths at approximately the scan frequency you intend to use (do this on an internal test pattern), this may save you a lot of convergence problems, including instability.
If you bought your projector from us deflection coil angles are definitely right, we do all projectors on an engineers table. If you seem to have a problem make sure the projector is mounted level. If deflection coil angle was set for a ceiling install and the projector is floor mounted there will be some error, and vice versa.
From: http://www.curtpalme.com/forum/viewtopic.php?p=86121#86121
You also asked about it back in 2013:
https://www.curtpalme.com/forum_archived/viewtopic.php@t=33308.html
Corleone88
| Posted: Mon Feb 26, 2018 10:34 pm Post subject: |
Thanks for the links Kal
