Picture size
Corleone88
Posted: Fri Feb 23, 2018 3:32 pm    Post subject: Picture size
Hello,
I don't understand why my picture is smaller on the screen with a 1080p72 signal, than with a 1080i72 signal on my BG 1209s connected to a Lumagen Radiance. I need to readjust the geometry to set the width to the max level.
Posted: Fri Feb 23, 2018 5:03 pm    Post subject:
It's not uncommon for a projector to change H width with different resolutions, but you can set up different memories within the Barco to accommodate that. Select '5' for 1080i/72, and '95'
for 1080p/72, or vice versa.
Corleone88
Posted: Fri Feb 23, 2018 5:15 pm    Post subject:
Ok but the difference between the two signals (about the width) is very big.
Looking through the lens, the picture does not fill the width fully(even with width set to max)
