Barry
Joined: 01 Feb 2007 Posts: 186 Location: Los Gatos , Ca.
| Posted: Sun Jan 21, 2018 5:21 pm Post subject: 1209 with Moome card ...any one tried this? |
Has anyone used the Moome card with 1209? I have been trying to get the Moome card to produce a high quality picture and have required extreme adjustments of BLACK/Contrast levels to bring the picture out of complete gloom and still dark scenes are buried. The Gamma adjustment on the Moome card clicks but is not responsive even in test mode of clicking 0 / 100.
Let me give you the latest information.
I moved to my other Lumagen, a Radiance XE which has no RGBHV only HDMI.
It offers a bit more range on adjustability. I set the BLACK level to MAXIMUM (64) and on the 1209 CONTRAST to MAXIMUM which brought scenes with bright pictures to a clean level that was reasonably good. White levels on both the settings are near middle. Raising them would destroy the picture.
When there are dark scenes in a movie they are totally washed out with a very weak image.
I found the best picture on setting B
The image source is a MacBook I have used for a long time for movies.
The massive black level corrections needed should be a strong clue regarding signal levels I assume. I have no way of measuring since I do not have a card extender. I might be able to get an oscilloscope to check levels if there is a test point.
_________________ Addicted to buying cool used expensive toys...(especially CRT projectors) Barco 1209, 1208 and Elektra Espresso Maxi2 most recent additions.....
