reset all settings to midpoint barco 1209g
SPL800
Posted: Thu Jan 04, 2018 7:39 am    Post subject: reset all settings to midpoint barco 1209g
i would like to calibrate my PJ (BARCO 1209G) from screech
how do i reset all settings to midpoint and delete all previous?
Hulio
Posted: Thu Jan 04, 2018 11:52 am    Post subject:
Both in service menu.
Adj--->Service--->Delete all blocks--->Enter
Adj--->Service--->Set to midposition--->Enter
It is best to go into dynamic astig menu, and set at 49 axial and diagonal for all zones on all three colors. Depending on soft. version, those may not be set to midpoint with all settings.
SPL800
Posted: Thu Jan 04, 2018 12:49 pm    Post subject: thanks
Thanks Hulio
will do them all
in order to get the best picture which important value should be kepped at midpositon and not played too much?
i know about raster shift any other important value?
Hulio
Posted: Fri Jan 05, 2018 8:09 am    Post subject:
Ideally, everything in geometry and convergence should be in the range 40-60. In practice, due to the complexity and electronics age, one must be happy with 30-70.
Less important are size, linearity, blanking, focus and dynamic astig. Those should be tweaked to whatever gives the best results on the screen.
It is imperative to mount the projector level and square with the screen, in order to achieve that.
