XG110 Error FC
jim80z
Posted: Tue Dec 26, 2017 1:25 am    Post subject: XG110 Error FC
Hi All
I hadn't used my projector for a very long time (been travelling/working a lot) but it has been plugged in on standby all this time.
I flicked it on yesterday:
- started ok
- within a second the green tube came on very bright with some overscan bright lines
- the red and blue stayed off from what I could tell
- within 5-10 seconds the projector shutdown with an FC code.
- after a few more seconds it came on by itself and repeated the above
The projector is connected to a Lumagen Vision HDP and a V1.3 HDMI Moome card.
I have read 3 other threads and people are mainly leaning towards power supply issues (but were not conclusive?).
On one thread it happened to be a lack of input setups caused the problem but I have seen this before when i reset the projector. I managed to get a vague picture of my inputs up before the projector shutdown and they seam to all be there. I dont think this is the problem.
I pulled the covers off the projector and noticed a flash from the SG5101 on the H-DEF PWB when the projector shutdown.
Any suggestions?
thanks
Jim
Posted: Tue Dec 26, 2017 1:34 am    Post subject:
That's going to be a tough one to try and troubleshoot. FD error is +15 volt supply line is low, but the last thing I'd suspect is the power supply, as the set is turning on. I'd suspect:
-shorted green tube (Sort of unlikely)
-bad video neck board on the back of the tube (more likely)
-almost any other board in the set.
I am selling XG boards for $10 USd each, minimum order 4 boards. I am getting out of XGs simply due to lack of demand, so what boards aren't sold by the end of January are going to the recycler.
jim80z
Posted: Tue Dec 26, 2017 5:05 pm    Post subject:
Hi Curt
Many thanks for the reply. Thanks for the parts offer but I have been fortunate to have heaps of parts from some other projectors I disassembled.
I changed the Green neck board without luck. Then replaced the HV and H-DEF PWBs (from memory they need to be in their original pair so both needed to be replaced?) and the projector is now starting up fine.
Now I have an interesting problem where the green tube has a dead phosphor area in the middle (not large but noticeable) and a a semi-vertical line bottom third of screen (outside the 16x9 area so not an issue) like someone scratch the phosphor. Is it possible that the phosphor degrades and flakes off the glass? These were new tubes (not rebuilds). The other two tubes changed at the same time are fine.
Thanks for all the help.
Jim
Posted: Tue Dec 26, 2017 5:22 pm    Post subject:
You have a spot burn. Rare on XGs, but possible. I did it to a set once when the red G2 lead was loose on the HV board, going to the green tube. That killed it instantly. The only tubes that I've seen flake off the phosphor are one batch of Sony ES focusing tubes, where the phosphor came off in chunks. Had a few of those way back when. I'd say some fault in the XG caused the burn, and not as a result of the tube itself.
jim80z
Posted: Tue Dec 26, 2017 5:37 pm    Post subject:
Hi
I figured the spot in the middle, although jaggy looking, may have been spot burn but the semi vertical line at the bottom threw me. I guess it could also be a burn as the gun traversed. Thanks for responding Curt. Much appreciated!
Jim
