Neck Board for Barco 1209
sukwoto
Posted: Fri Oct 13, 2017 6:00 am    Post subject: Neck Board for Barco 1209
Hello, I need Neck Board for CRT Projector 1209 Barco.
Pls advice
Thank you
Pokemon640
Posted: Fri Oct 13, 2017 11:25 am    Post subject:
i have some neck boards for 1209,
Barco R number of your current neck board?
what kind of tubes you are using ?
did you have any issues ? or you are looking for spare parts ?
Posted: Fri Oct 13, 2017 1:53 pm    Post subject:
He needs some, I am now out of stock. They are MEC tubes, no red focus lead attached. 772282 or 292, I can't remember. THe ones out of a 1208s, with the red focus wire will NOT work. He needs the black metal box, square video neck boards.
Posted: Fri Oct 13, 2017 4:04 pm    Post subject:
It is perhaps easier to repair the boards than find a spare, those are rare...
Posted: Fri Oct 13, 2017 7:10 pm    Post subject:
I don't even have a 1209 test chassis any more, so I can't assist sadly.
Posted: Sat Oct 14, 2017 12:48 am    Post subject:
The 1209 and 1209/2 used both MEC and Sony tubes. So those black box style RGB amps come with and without the focus red wire. So we at least need to know which style is required.
sukwoto
Posted: Sat Oct 14, 2017 1:47 am    Post subject:
The number is R 762292
Posted: Sat Oct 14, 2017 2:10 am    Post subject:
Without the red wire, they are MEC tubes. I've sold him 3 neck boards in the last year. Not sure why they are shutting down, I suspect a bad connection between the tube and CRT socket frankly..
Pokemon640
Posted: Sun Oct 22, 2017 9:01 pm    Post subject:
i have different R number
R762839 (3 PCS)
R762746 - R9032098 (2 PCS for 808S)
Sorry
sukwoto
Posted: Mon Oct 23, 2017 3:01 pm    Post subject:
R762839 (3 PCS)
Sorry
Ok..no prob
Posted: Mon Oct 23, 2017 4:58 pm    Post subject:
Those board numbers are off a 1209s, they will not work in a plain 1209, sorry!
Posted: Thu Oct 26, 2017 7:45 am    Post subject:
He needs the black box type RGB amps for MEC tubes.
