Moome Ext-V3 question
jbltecnicspro
Posted: Wed Aug 23, 2017 1:14 am    Post subject: Moome Ext-V3 question
Good evening all,
I'm set to buy a Moome Ext-V3 for my projectors. I'm currently using a Yamaha DPX-1200 whose HDMI input doesn't work. The Moome will feed the Yamaha via RGBHV.
Question - I would like to experiment with the Moome contrast adjustment, which apparently starts at 0.7 volts as peak white going all the way up to 1.0 volt. The idea of this will be to increase the white level so that lower-brightness movies would be brighter.
Would I be hurting the inputs of the Yamaha if I did this? Thanks.
