Possible power relay issue on a Sony VPH-1252
Audio_Geek_00
Posted: Thu Jun 29, 2017 6:53 pm    Post subject: Possible power relay issue on a Sony VPH-1252
Went to turn on the projector and Sad
I can hear a relay click twice in quick succession when pushing the power on button on the remote. At first I thought I hadn't held the button down long enough so I tried several more times and nothing. I then tried the power on button on the pj thinking the batteries in the remote were the issue and got the same result.
In between the two relay clicks the fans and the power LED lights come on then nothing after the second click. Is there a power relay that could go bad?
TIA
Tim
Posted: Thu Jun 29, 2017 8:20 pm    Post subject:
No, there is no such thing as a 'power relay' in the 1252. Under the cover is an 2 digit display that shows an error code. If it's ceiling mounted, you'll be reading it upside down. What does that LED display indicate? (location is shown on the main site in the tech tips area of the 12XX series)
Audio_Geek_00
Posted: Thu Jun 29, 2017 11:07 pm    Post subject: Sony 12XX
Curt,
I'll pull the cover tonight when I get home and check the display. Is the error code continuously displayed?
Tim
Audio_Geek_00
Posted: Thu Jun 29, 2017 11:13 pm    Post subject:
I should have did what you said before I asked the question. I know where to look and where the error codes are.
Thanks.
Tim
Posted: Fri Jun 30, 2017 12:50 am    Post subject:
Yes, once the set has powered off the display should stay on. Also check to see that the fans do spin up momentarily under the cover
Audio_Geek_00
Posted: Fri Jun 30, 2017 4:18 pm    Post subject: Error code on 1252
Curt,
The error code is 13. Referring to the error code chart there is a Y for FAN stop, (H stop) 100V down and HV-over.
Does that mean a fan is out which affects cooling of HV power supply?
Best,
Tim
Posted: Fri Jun 30, 2017 7:56 pm    Post subject:
Possible, although it's more likely that the PA board or H board has failed. Still, check all 7 (?) fans in the set to see if they spin. There are two on the back of the power supply that you can't see, you'll have to pull out the power supply to check those. Do this with the set on a table, as it's a PITA to remove the power supply while it's on the ceiling.
Audio_Geek_00
Posted: Fri Jun 30, 2017 9:22 pm    Post subject: Hmmm...
Thanks for the info Curt. My thought after babying the pj along for the last 10 years is if it comes off the ceiling one more time it won't be going back up. Where is the PA board and H board located? What is their function? I don't see anything in the diagrams of the pj layout referring to those 2 boards.
TIA,
Tim
Posted: Sat Jul 01, 2017 12:12 am    Post subject:
The H board is the big flat one under the top cover that is over top of the green and blue tubes (right under the top cover). The PA board is the one on top of the power supply under the lenses.
Audio_Geek_00
Posted: Sat Jul 01, 2017 3:05 am    Post subject: Boards
Curt, do you have any of these boards or are they repairable?
TIA
Tim
Posted: Sat Jul 01, 2017 2:05 pm    Post subject:
I should still have a working H board in stock. Not worth sending yours up, too expensive, and I don't have a 12XX projector any more to repair them.
Audio_Geek_00
Posted: Mon Jul 10, 2017 8:51 pm    Post subject: Sony 12XX H and PA board
Curt, you thought you might have a working H board. Have you had an opportunity to check? Also, you thought it could also be the PA board. Is that something that is attainable?
I will be gathering the required number of bodies to get the PJ off of the ceiling to check the fans this weekend. If I find any that are not functioning what is the recommended replacement?
If I find that the fans are functioning and I can't get the replacement parts then I will put the PJ on the Buy and Sell forum. The vertical board was replaced August 2016 and the tubes Feb. 2015. Maybe it can live on with someone else.
TIA
Tim
gregstv
Posted: Tue Jul 11, 2017 9:16 am    Post subject:
I have stripped one of these. I have all boards if Curt can't help you. The biggest problem will be the cost of shipping from Australia.
Posted: Tue Jul 11, 2017 4:16 pm    Post subject:
Yes, I do have one. Did you send me an email to curtpalme at shaw.ca? If so, I haven't gone through my emails recently to follow up. Will try to get to all of them by the end of the week.
Audio_Geek_00
Posted: Tue Jul 11, 2017 11:00 pm    Post subject: boards
Thanks mate! Looks like Curt has what I need but if something else comes up I'll look you up.
Best
Tim
