Ampro 3600 brightness issue
paterlucas
Posted: Fri Jun 16, 2017 9:05 am    Post subject: Ampro 3600 brightness issue
Hello,
My ampro started to act up, at first the brightness on the red tube started to vary until the whole tube started to go dim.
The tube does show a picture but not enough to project this on a screen.
As a test i tried swapping neckboards and the problem moved to the green tube.
Does anyone know this problem, or were to start looking?
Thanks in advance,
Lucas
Posted: Fri Jun 16, 2017 9:09 am    Post subject: Re: Ampro 3600 brightness issue
paterlucas wrote:
Hello,
Thanks in advance,
Lucas
If you shifted neck cards (RGB Output AMPS) and the problem went with it then that neck card is probably the root cause of the issue.
Posted: Fri Jun 16, 2017 1:44 pm    Post subject:
Exactly! I should still have a couple of spares if you need one.
