What am I doing wrong?
jbltecnicspro
Posted: Sun Apr 23, 2017 9:00 pm    Post subject: What am I doing wrong?
Good afternoon all,
A couple of times, I've tried to calibrate my DLP projector (Yamaha DPX-1200 if you need the model number) using my old DTP-94 colorimeter and I've had terrible luck. I just cannot position the puck to see the screen properly it seems. I'm very sure that my meter isn't broken (it has no problem reading direct view displays).
I'm using HCFR and using Argyll CMS drivers for it, if that makes a difference.
And yes Kal - I'm aware that my meter is old and I probably need a new one for more guaranteed results. But I have what I have at the moment. I would love to afford an i3 Display and a spectro to recal it every time but I cannot afford to do so. Very Happy Thanks in advance.
Posted: Sun Apr 23, 2017 10:44 pm    Post subject:
When you say "I just cannot position the puck to see the screen properly" what do you mean exactly? What problem(s) are you having exactly?
jbltecnicspro
Posted: Mon Apr 24, 2017 11:25 am    Post subject:
Whenever I try to take a reading from the screen, I'm getting some really "off" measurements. If I do a full white screen, for example, HCFR says that it's only getting a reading of Y = 7 (which is measured in cd/m2 or nits I believe). There's absolutely no way that the meter can be seeing the screen correctly because 7 cd/m2 is pretty dark. I don't remember the exact ft lamberts measurement but it's super low. Which can't be right because the light output is very much bright enough for movie viewing.
Posted: Mon Apr 24, 2017 4:07 pm    Post subject:
7 cd/m2 is only about 2 foot lamberts so definitely not normal. That's really dim. Not sure why it's happening. Assuming you're not reading the shadow.
Normally you face the screen and play with it a bit until you max out the Y value and go from there.
jbltecnicspro
Posted: Tue Apr 25, 2017 12:00 am    Post subject:
I'll give it a shot again tonight. I should have some time. I think I'm reading the shadow. Where should I place the meter? My projector is table mounted and is a DLP projector, so only a single source of light.
I want to place it near the screen but obviously the closer I get the more prone to reading its shadow the meter becomes. Do I need to hold the meter at an angle?
Posted: Tue Apr 25, 2017 12:24 am    Post subject:
Angle is definitely required. See the instructions and pics here:
https://www.curtpalme.com/forum_archived/viewtopic.php@t=10457.html
jbltecnicspro
Posted: Wed Apr 26, 2017 10:11 pm    Post subject:
Okay, well I was able to get the meter to read a little better but it was only 20 cd/m2 at the brightest iris mode of the projector. It's a new bulb (only 175 hours) and only projecting on a 92 inch 1.3 gain screen - not to mention it's pretty damn bright, so I'm sure I need to experiment more. I will probably need a tripod as my arm was tired after walking around the room and holding my meter up. Very Happy Thanks for the help Kal.
Posted: Wed Apr 26, 2017 10:43 pm    Post subject:
Walking around the room? Put the meter a few inches from the screen. If you're more than a foot or two away, you may be picking up dark areas.
See the instructions and pics for meter placement in the link I posted earlier:
