Corleone88
| Posted: Tue Jan 03, 2017 2:52 pm Post subject: HDMI cable for 1080p72 signal |
Hello,
I have a BG 1209s with HDMI port which I need to plug to a modified Lumagen XD outputing 1080p72. I need a 7m (approximately) HDMI cable. Which brand should I choose to avoid any problem?
| Posted: Tue Jan 03, 2017 3:07 pm Post subject: |
It's a crapshoot at best. Some dirt cheap Chinese cables work fine, some high end cables won't work. It's also somewhat dependent on the source and destination hardware. All you can do is try and see if one works.
massive
| Posted: Fri Jan 20, 2017 7:38 pm Post subject: |
I noticed that your knowledge and information are very interesting and useful. I greet you.
kal Forum Administrator
| Posted: Fri Jan 20, 2017 8:58 pm Post subject: |
| massive wrote: | | I noticed that your knowledge and information are very interesting and useful. I greet you. |
I greet you too. Can you tell us a little bit about yourself? I want to confirm you're not a spammer as unfortunately your post is very typical of the content a spammer would post (generic wording). Thanks!
massive
| Posted: Fri Jan 20, 2017 9:05 pm Post subject: |
I'm interested in home theater, i'd like to know your technical skills if I will have some problems. I am Michael and I'm from London
_________________ http://lan-utan-uc-se.com/
| Posted: Sat Jan 21, 2017 7:31 am Post subject: |
| massive wrote: | I'm interested in home theater, i'd like to know your technical skills if I will have some problems. I am Michael and I'm from London  |
This sounds like the beginning to a 'Home Theater Anonymous' meeting.
Hi My name is Analog and it's been 3 days since I last fired up a projector. haha
