silv55
| Posted: Fri Dec 09, 2016 5:21 am Post subject: |
IF all menus work fine, then you're most lilkely correct, the input board or main CPU board is bad. Best bet is to take a chance and buy another used one on eBay, but assuming that this is a few years old, and considering Pioneer is long out of the TV market, I'd scrap it and get something else.
| Posted: Fri Dec 09, 2016 6:45 am Post subject: |
try all inputs one by one and see if any give you a picture.
silv55
| Posted: Fri Dec 09, 2016 7:55 pm Post subject: |
Thanks guys;Today i had to clean the boards cause they were full of dust and durt , i used a Vacum cleaner ,
now power supply won't turn on,i only have the 125v at Fuse 1 and no volts at all, it's dead now with only steady red light that i can switch off and on on the main switch.
i reed somewhere about a light sensor Pioneer uses the trap switch ,can you guys elaborate on this,thanks
