Can Barco 808 components be used for marquee or G70?
haireez
Posted: Sat Dec 03, 2016 1:25 pm    Post subject: Can Barco 808 components be used for marquee or G70?
Just curious if Barco 808 magnetics can be use for 909 tubes?
2 White Vision 1
Posted: Sat Dec 03, 2016 11:17 pm    Post subject:
909 has 6 pole electronic astig 808 has 4 pole so providing the coils are the same you would need to make changes to wiring and of course lose part of the control system that makes the 909 so sharp.
I am assuming you wanted to put 808 magnetics in a 909 projector. On the other hand if you want to put 909 tubes in an 808 chassis then no problem.
haireez
Posted: Sun Dec 04, 2016 6:16 am    Post subject:
I have someone here in Singapore that wanted to give away his non working 808 but not too sure any component that I can salvage or use for my Vision 1.
Or maybe any useful component that can be use to improve G70 for my local friend here. Any advise would be great before we dispose the non working 808.
2 White Vision 1
Posted: Mon Dec 05, 2016 5:02 am    Post subject:
Except the CPC magnets I don't believe there are any common parts for those projectors. Someone else may be able to definitively tell you about tube compatibility.
haireez
Posted: Fri Dec 09, 2016 11:06 am    Post subject:
It seems that it's of no use for G70 or 9" Marquee. Likely going to the thrash.
2 White Vision 1
