4 K
larryp
Posted: Sun Oct 23, 2016 5:02 pm    Post subject: 4 K
I have a Sony 1272 running 1080I.
I know the projector can't handle 4k,, but was wondering If I watched Netflix 4k, Would I see ANY noticeable improvement in picture quality? Just curious
Posted: Sun Oct 23, 2016 6:25 pm    Post subject:
How are you even going to get the 4K signal into the projector?
Some Lumagen scalers can downsample 4K to something your projector can handle, but you can not get a better
image quality than the resolution being delivered to the projector.
4K sharpness can not be conveyed in a 1080p signal.
4K is a dream for CRT projection enthusiasts, one that is highly unlikely to come true unless we get a CRT enthusiast in
our community who has the desire and the the resources to spend millions of dollars developing a super high bandwidth
CRT projection system that currently does not exist.
You'd be much better off to upgrade to a top 9" CRT projector for image quality improvement, or if 4K is really what you want,
get a 4K digital like a JVC RS...whatever.
larryp
Posted: Sun Oct 23, 2016 10:28 pm    Post subject:
It's just a information question. Just wondering if the picture would change at all. Not looking to upgrade anything either.
Posted: Mon Oct 24, 2016 1:48 pm    Post subject:
But like CM said, you can't get 4K into the projector, so therefore you can't watch Netflix 4K. It's not a logical question.
larryp
Posted: Mon Oct 24, 2016 5:43 pm    Post subject:
You don't understand , never mind
Posted: Mon Oct 24, 2016 6:09 pm    Post subject:
To answer your real question: probably no. The 1272 can already display only a portion (probably 3/4?) of 1080P, so if we believe downscaled 4K looks only slightly better than native 1080P content, then further downscaled (even if it is done by the electron beam of your Sony) will give undetectable difference.
On the other hand I think we live the days still when vast majority of the 4K materials are only "look better" because a good ammount of edge enhancement was added to the original content. But honestly for that you don't need 4K...
Posted: Mon Oct 24, 2016 7:30 pm    Post subject:
Larry,
Did you mean like this?:
4K source -> video processor to downscale to 1080i -> Sony 1272 projector
If that's the question, then no, it won't make any difference.
the dude
Posted: Thu Oct 27, 2016 4:52 am    Post subject:
I disagree, its not all about number of pixels...
It makes a difference where the downscaling ocours! Thats because all video codecs use spectral data reduction, so if you downscale to 2k and compress the compression removes information that you can see. If you compress 4K material in the first place data compression affects information that is invisible in 2k anyway.
But maybe it makes no difference when streaming, it depents on the actual bitrates.
Posted: Thu Oct 27, 2016 5:36 am    Post subject:
Normally, you'd have a point. The problem is the 1272 is only resolving somewhere around 720p. It's a little better than 540p, but not even close to 1080p. So, how much difference will be visible between content compressed at 1080p, and content compressed at 2160p, but all displayed at 1080i and resolving something much less than that? Answer: Zilch.
Posted: Thu Oct 27, 2016 6:24 pm    Post subject:
LOL, I was thinking the same.
Larry,
There are plenty of 8" pjs out there for next to nothing. Why don't you pick one of those up?
