Electronic parts life.
deronmoped
Posted: Fri Oct 07, 2016 4:04 pm    Post subject: Electronic parts life.
Now if you had two parts, one NOS and one being used, would the NOS last much longer? I know caps are the main issue, and heat and loading will degrade all the parts, but how fast will caps fail from just old age? I have some old radios, tube and transistor that are sixty plus years old and still working on original parts, what is the deal there?
Posted: Fri Oct 07, 2016 5:44 pm    Post subject:
Not an issue with transistors or resistors. Those fail due to excessive current and heat. Sitting on a shelf, they'll be fine.
Posted: Fri Oct 07, 2016 6:17 pm    Post subject:
Actually, though it's a very slow process, semiconductors can fail just sitting on the shelf due to the process of diffusion of the N and P dopants thru the silicon substrate. This happens more rapidly at higher temperatures.
Posted: Sat Oct 08, 2016 3:25 am    Post subject:
Enough!
CM claims to be a humble technician.
Only an engineer would know this stuff.
So fess up! LOL
deronmoped
Posted: Sat Oct 08, 2016 5:57 am    Post subject:
What are we talking, years or decades for semiconductors.
Posted: Sat Oct 08, 2016 12:17 pm    Post subject:
Decades, unless you run the chips very hot. Like, hot enough to lose your fingerprints if you touch them.
