Murideo SIX-G 8K Video Test Pattern Generator
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> ChromaPure Products
Posted: Wed Sep 21, 2016 8:53 pm    Post subject: Murideo SIX-G 8K Video Test Pattern Generator
Order today! GO »
The Murideo 8K SIX-G is an HDMI pattern generator intended for the AV integration market to confirm HDMI 2.1 and HDCP 2.3 / 1.4 operation at the 40Gbps level. This device can create a signal that allows it to act as any modern HDMI source. Additionally, the SIX-G is an excellent field troubleshooting tool for distributed high bandwidth HDMI systems and a reference source for video calibration.
The handheld device is portable thanks to a built-in battery and can generate over 100 different test patterns for setup, calibration, and troubleshooting. There’s a three-inch color display with simplified menus as well as free PC control software. The 8K SIX-G also features Hot Plug Detect, EDID read/write functionality, and the ability to create custom resolutions. There’s the option for either RS232 or USB control and support for Calman and Light Illusion calibration software. The 8K SIX-G is the only unit to carry the complete suite of ISF test patterns, select-able color output level, RGB Triplets, and Constant APL (Average Picture Level) all in one place. The 8K SIX-G is a calibrator’s dream because it’s: ISF Labs certified, the firmware is field upgradable, and it even includes audio confidence tests.
Supported by ChromaPure Professional.
For complete details see our order page here: http://www.curtpalme.com/ChromaPure_Murideo.shtm
Confused about meters? See our FAQ: Which meter is right for me?
Order today! GO »
Posted: Fri Mar 03, 2023 4:54 pm    Post subject:
8K version now available!
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> ChromaPure Products All times are GMT
