tromatus
| Posted: Fri Jul 29, 2016 11:03 am Post subject: BARCO 1209 problem |
hi everyone.
i have a barco 1209s it works fine until now...
today there is not picture,not internal paterns and menu.
on all tubes
when i run it,everything seems to work fine,fans,boards,ect...
but i dont get image .
anyone have an idea??
EDIT: i try it few time ago.
its works fine
but after alf hour,same thing,the picture
goes out...
thank you
manu
| Posted: Fri Jul 29, 2016 1:29 pm Post subject: |
Check the red light on the EHT board to see if it comes on. Most likely it is, meaning your HV splitter or quadrupler is bad. I've got both in stock.
Thanks!
tromatus
| Posted: Sat Jul 30, 2016 9:06 pm Post subject: |
| Curt Palme wrote: | Check the red light on the EHT board to see if it comes on. Most likely it is, meaning your HV splitter or quadrupler is bad. I've got both in stock.
Thanks! |
thank for the answer,
i have 3 quadruplers R7622091.
this ref is ok for the 1209S?
| Posted: Sat Jul 30, 2016 9:48 pm Post subject: |
Electrically yes, but they won't fit properly.
tromatus
| Posted: Mon Aug 01, 2016 8:05 am Post subject: |
| Curt Palme wrote: | | Electrically yes, but they won't fit properly. |
ok tanks.
is electrically compatibility is ok.
i going to try to modify barco structure
to fit that properly...
if i cant,i will get one quad from you
Decibel
Joined: 31 May 2007 Posts: 904 Location: Roma - Italia
| Posted: Mon Aug 01, 2016 8:34 am Post subject: |
Where do you live?
_________________ Domenico (Barco fan!)
tromatus
| Posted: Wed Aug 17, 2016 9:13 pm Post subject: |
i check my barco HV line today.
the EHT bord is R eht r762716
anyone know if the R7622091 quad is compatible
whith this EHT board?
thanks
Decibel
| Posted: Thu Aug 18, 2016 1:55 am Post subject: |
| tromatus wrote: | i check my barco HV line today.
thanks |
Yes it's compatible.
