Current surround sound receiver model
Posted: Thu May 19, 2016 7:58 pm    Post subject: Current surround sound receiver model
Guys, I have a commercial client that has set up a 7.1 system in a gymnasium. With no room treatment, it sounds pretty bad as you can imagine. They use it all the time though, but want it upgraded. They are running a Harman AVR645 right now with.. <drumroll please>... composite video switching! In fact, they don't even use the Harman as a video switcher, they manually switch RCA cables between a VHS machine and DVD player. Yes, it's a small town. Mr. Green
The projector is a 6 year old 6000 lumen Eiki with DVI input.
So here's what I am suggesting...
-add some room treatment via acoustic panels that I have a supplier for
-take down the rear surrounds, and go to a 5.1 system, which will most likely sound better due to less speakers in the reverberant room.
Then, either go with a video scaler to upscale everything to HDMI to the projector,or get a new AV receiver with upscaling for their VHS machine, and install a Bluray player as well,and a VGA input for their computers (and an HDMI input as well on the gym floor)
It has to be BULLETPROOF! I am leaning towards an upscaling AV receiver, but don't know how many will have a VGA input. Unfortunately, with the Lumagens not having front panel pushbuttons, they are out. I could use an industrial scaler, like a Kramer or Extron, have easy to read pushbuttons on the front, then send the audio to the existing H/K which will only be used for surround sound processing.
I am however leaning towards an AV receiver, as the front panel display is alphanumeric and programmable, and rotating the source selection switch would change inputs. The front panel HAS to be clean though like the old H.K AVR receivers, I don't need anyone pushing a tape monitor button, then screaming for help. This place is 3 hours out of town, I can't afford warranty service calls.
So, what I need:
-video, VGA and HDMI inputs, with upscaling, most likely to 720p only, as that's what their projector is.
-1 or 2 HDMI outputs
-5.1 preamp outputs, as they use powered speakers in the room along with a subwoofer amp
-super simplistic AV switching
I could probably go used, but I don't want to run into HDMI board problems which is what plagued Pioneer and Onkyo a few years ago.
Whatcha got?
Posted: Fri May 20, 2016 6:49 am    Post subject:
A couple of thoughts...
No reason to take down the surround-back speakers. The acoustic treatments should improve the sound; if they do, the rear fill might be nice depending on the shape of the room. Either way, no need to deinstall them; simply turn them off in the AVR's surround setup. Leaving them in would at least allow you to A-B test with/without after the acoustic treatments are installed and see which way sounds better.
I like your idea of letting the AVR do the switching - just twist the knob. Stupid simple operation. Simple is good.
You don't need a preamp or receiver with a VGA input, though. Just use a good VGA-to-HDMI A/D converter; VGA input, HDMI output, and connected to one of the preamp/AVR inputs. Kramer, Extron, Atlona, Gefen all make good converters with audio and scaling.
Very few AVR's have preamp outputs until you get up there in the range, and then you'll be getting close to what an entry-level prepro costs.
How about a Denon DN-500AV? $900 retail. Pro/commercial market product. Balanced outs only. The only other pro/commercial market product that isn't mega-bucks is the Onkyo PR-SC5530, and even it would be massive overkill. That leaves some consumer gear...
The Marantz SR-6010 front panel is stupid-simple without the door dropped down - two knobs - and is their lowest-end AVR with pre-outs. It's $1400 MSRP, the problem I was talking about earlier.
The cheapest Denon with pre-outs would be the AVR-X3200W at $999. Yamaha and Onkyo/Integra all have similar offerings that would work. The Onkyo TX-RZ800 has preouts, but the front panel is a little busy. Integra is a dealer-only product, but like the Onkyo it has a lot of buttons on the front panel.
I'd probably lean toward the Marantz SR-6010, or if the client is OK with it, accessories4less has the 6009 as a factory refurb for $499, which is a total steal.
http://www.accessories4less.com/make-a-store/item/marsr6009/marantz-sr6009-7.2-ch-x-110-watts-networking-a/v-receiver-bonus-hdmi-cables-100-value/1.html
Cheers,
Posted: Fri May 20, 2016 1:20 pm    Post subject:
Thanks for the info. I've actually been leaning towards the scaler, just because it's most likely going to outlast any consumer AV receiver, and the HK that they have is a pretty bulletproof unit. I've got a call into Kramer to make sure it will strip/switch the audio from every input type, but I think it does. Will look at your suggestions as well though.
Cheers!
Posted: Fri May 20, 2016 2:23 pm    Post subject:
I like your idea to go 5.1 and lessen the rear speakers. Being a gymnasium, the average HT Receiver would not have the delay for rear speakers that would be needed for that size room. And even for the two 5.1 rears, you may still have to add a delay. Not sure if it's not already in the one you're looking to upgrade to.
Posted: Fri May 20, 2016 2:54 pm    Post subject:
That's my gut reaction, but Steve is right. Leave the speakers installed, try them, and disconnect them if it sounds worse.
I am quoting in a Rane HAL system as well with touch screens with multiple presets to reconfigure the sound system (they also have a separate in-ceiling speaker system) depending on the function. If they spend the $$, they will LOVE it! The Rane is super intuitive to use, and the touch panel is dirt cheap compared to a Crestron system.
Posted: Fri May 20, 2016 4:51 pm    Post subject:
The Hal would be perfect with its powerful DSP drop in processor features, and because of that you'll have the flexibility to do whatever and it'll meet any room or configuration need.
