Problems watching tennis with lumagen 2041/2042 out of sync
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> Lumagen Products
yin
Posted: Sat Apr 23, 2016 5:17 pm    Post subject: Problems watching tennis with lumagen 2041/2042 out of sync
watching Tennis with the Lumagen can be very discouraging because it frequently goes out off sync, you then se the tennisball double.
How can I get the sync to work correctly?
Posted: Sat Apr 23, 2016 5:28 pm    Post subject:
What Radiance are you using?
What source? What is the resolution/refresh rate of the source?
What resolution/refresh rate do you have the output of the Radiance set to?
What display (make/model)?
What length and brand of HDMI cable do you have between the source and the Radiance?
What length and brand of HDMI cable do you have between the Radiance and the display?
Are there any other devices between the source and the display or is it straight: Source -> HDMI cable -> Radiance -> HDMI cable -> Display
yin
Posted: Sun Apr 24, 2016 3:13 pm    Post subject:
What Radiance are you using? 2041/2042
What source? What is the resolution/refresh rate of the source? Sat Receiver 1080i/50Hz
What resolution/refresh rate do you have the output of the Radiance set to? 1080p/50Hz
What display (make/model)? Sim2 Lumi 3D-s
What length and brand of HDMI cable do you have between the source and the Radiance? 1 meter
What length and brand of HDMI cable do you have between the Radiance and the display? 10 meters
it goes straight to the Sim2
The problem is only with Tennis
Posted: Sun Apr 24, 2016 4:44 pm    Post subject:
It's not just Tennis - It's the speed at which the ball (or any object) moves and the fact that the source chose to capture and/or broadcast in interlaced which means 2 passes are required to capture and there's a slight shift between frames, enough for the ball to move. Usually sports is done in progressive instead of interlaced for this exact reason.
More info: http://www.cnet.com/how-to/1080i-and-1080p-are-the-same-resolution/
Posted: Mon Apr 25, 2016 2:07 am    Post subject:
You may need to enable field flip in the Lumagen for your source. Some interlaced sources provide the frames in the opposite (wrong) order and this must be manually set in the Lumagen to correct. It's in the input menu.
Some displays and other devices can fix a flipped field on their own making you think the Lumagen is the fault, but it's really just a crap shoot and the Lumagen provides a way to fix the error in the source.
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> Lumagen Products All times are GMT
