8500 9500
deronmoped
Posted: Sat Apr 23, 2016 2:53 am    Post subject: 8500 9500
Anybody throwing out a PJ, or a bunch of parts? I got a 9500 out of a alley, it's a good model, but I think it saw some rain. I got it partially working, but I'm afraid I might be throwing a bunch of parts at it. It's flaky in operation right now, I been running it to see what it's going to do. It ran fine once, then a neck board went out and it seems the LVPS has a mind of it's own.
Posted: Thu Apr 28, 2016 3:03 pm    Post subject:
Hey Deron
Go in and clean all the connections you can get to, the guys recommend Deoxit cleaner; you may have some corrosion from water getting in. Look especially at the top mother board.
tschaeikaei
Posted: Fri Apr 29, 2016 10:39 am    Post subject:
Did you exclude glycol leaks by now?
It's very common on marquees and could cause all kinds of sh*t.
Regards, Julian
deronmoped
Posted: Sun May 01, 2016 7:03 pm    Post subject:
Thanks guys.
Yeah, I have been going though and cleaning connections.
I have not seen any evidence of glycol leaks yet.
Most of the boards looked pretty good, some looked pretty bad, the ones on the back heat sink had all kinds of corrosion and dirt. They had this PJ in the alley with the lenses pointing to the sky.
Posted: Sun May 01, 2016 7:13 pm    Post subject:
Say Deron
Try unplugging the two ribbon cables to the rear heat sink and then try powering up. You will not get high voltage with the vertical board unplugged but if it does power up then your problems are narrowed to vertical, convergence and stig amp.
