jose carlosv
| Posted: Wed Apr 20, 2016 7:32 am Post subject: doubts calibration some sources |
First of all hello, i am a new member in the fórum, my name is Jose and i am from Spain.
i am new in the world of calibration too but i think it is fascinating so i am trying to learn as much as i can.
Finally i decided to buy a LG OLED, and as i can see it is clearly that if i make a good calibration of my tv i can have even a better picture quality.
I have a old Toshiba LCD 32" to train, but i have some doubts.
Now i am using a Xrite i1 display pro and AVSHD 709 calibration disc plus HCFR sofware to training myself in the Toshiba.
The source is a LG BP740.
As much as i know i need to make a calibration to each source, is that correct?
In my particular case if i make a calibration and then change for example LG BP740 for another BD players like Samsung, Panasonic, Sony etc maybe the settings are incorrect in the tv, is this right?
I have an old betamax collection, is a pal system.
How i can calibrate the tv for this source? Maybe using a PAL DVD pattern as a reference?
Hope you can help me.
thanks
kal Forum Administrator
| Posted: Wed Apr 20, 2016 12:42 pm Post subject: Re: doubts calibration some sources |
Welcome to the forum Jose!
| jose carlosv wrote: | | As much as i know i need to make a calibration to each source, is that correct? In my particular case if i make a calibration and then change for example LG BP740 for another BD players like Samsung, Panasonic, Sony etc maybe the settings are incorrect in the tv, is this right? |
Each display needs to be independently calibrated. Most people do have different calibrations for each source however. That's certainly something you can try (if you display supports a per-input calibration or you have an easy way to toggle back and forth).
Most people do not different calibrations for a display for each source because it's a pain and more importantly: Because most sources will provide similar signal levels if things are set the same between sources. For example, many sources will let you choose between a 0-255 or 16-235 signal range. Set all your sources the same way and calibrate to that. I would also turn off any image enhancement features or similar in the source that could affect greyscale/colour/gamma. Just have the source send the signal "pure".
| Quote: | I have an old betamax collection, is a pal system.
How i can calibrate the tv for this source? Maybe using a PAL DVD pattern as a reference? |
I would simply calibrate the display using your 'best' source (likely Blu-ray or similar) and be done with. You'll likely get 99% of the way there with other sources.
Good luck!
jose carlosv
| Posted: Wed Apr 20, 2016 2:05 pm Post subject: |
Many Thanks for help me.
i just read the grayscale calibration for dummies and i believe to understand that d65 grayscale is independent of gamut and is the same in SD and HD.
So if i can calibrate properly the grayscale, and if i make a good calibration of REC709 to my best source (in my case the LG BLURAY), PAL gamut and REC709 gamut are not much different like REC709 and NTSC so maybe i have a good start point to see the SD and my old betamax tapes whit HD calibration settings
jose carlosv
| Posted: Thu Apr 21, 2016 9:02 am Post subject: |
Thanks for all.
I have a last doubt.
Is correct to say that if you see a upscaled DVD in a bluray player this source converts PAL gamut in my case in REC709 HD gamut?
