Zolzar
| Posted: Thu Apr 14, 2016 1:56 pm Post subject: TAW Rock Pro or Lumagen Vision HDP??? |
I have both but currently use the Lumagen. I'm trying to cleaning stuff I don't use/need. Which scaler would you recommend I keep?
Using NEC PG10 with HDFury. Only drawback I see right now is the TAW won't accept a 1080 signal where the Lumagen does.
kal Forum Administrator
| Posted: Fri Apr 15, 2016 8:33 pm Post subject: |
What do you use the scaler for exactly?
If only for scaling you may no longer need it given that most sources have scalers built in now that works well enough. I never used one with my CRT projector given that my sources were either HTPC (a loooong time ago), PS3, satellite box, or AppleTV. All were able to scale sources to the 1080i/60 I used.
If you have specific needs and both give you what you need, I'd keep the Lumagen simply because that the company's still around and the scaler's more common if you need help.
Zolzar
| Posted: Sat Apr 16, 2016 2:05 pm Post subject: |
The only thing I only need the scaler for on rare occasion to playback VHS or some of my old Hi8 videos. Other than that it's honestly useless. I'm going to stick with the Lumagen. The TAW will get recycled.
I had an HTPC back in 2001 when I got my first projector, ECP3101. Those were the days.
