BT2020 with CRT
ElTopo
Posted: Sat Mar 12, 2016 2:36 pm    Post subject: BT2020 with CRT
May this be possible with the correct color filters ?
cheers
ElTopo
Barco Cine 9 the one and only
Posted: Sat Mar 12, 2016 3:15 pm    Post subject:
No, not in any practical sense. BT2020 pushes red, green, and blue farther out than anything before.
The CRT phosphors just don't put out much light at the target RGB values for BT2020.
All color filters do is eliminate the wrong colors, they can't create the right ones.
Posted: Sun Mar 13, 2016 4:27 pm    Post subject:
Here is one CRT colorspace chart that outlines the differences between NTSC, HDTV, and the UHD BT 2020 specification.
Our CRTs are built with phosphors selected for good performance offering a compromise between color accuracy and light output. They were chosen when NTSC was all we had, long before the advent of HDTV and even before the computer had any presence in the home.
Not all phosphors are capable of the high light output needed for a projection CRT. That's why we use red and green C elements for greatest color accuracy. But by doing so, we're throwing away some light output and driving the tubes harder, resulting in reduced tube life.
Filtering for BT 2020 would seem to be unlikely to be successful.
None of our CRT native colors are very close to the BT 2020 specs. Red isn't deep red enough, blue would have to move toward indigo, and green would have to be deeper green as well.
Posted: Wed Mar 16, 2016 5:40 pm    Post subject: Re: BT2020 with CRT
cheers
ElTopo
Right now we need to be more concerned with the ability to reproduce the DCI P3 color gamut. While UHD is using Rec2020, all the BD's and content will be mastered within the DCI P3 gamut for the foreseeable future. There aren't even any digital projectors or panels that can reproduce Rec2020.
So basically the HDMI color space will be Rec2020, but only the colors inside the DCI P3 gamut will ever be addressed.
It may not be possible for CRT to produce DCI P3, or even if it can to still have enough light output. But the possibility of reaching DCI P3 with CRT is more likely than Rec2020.
