BG1209s High Voltage gone?
studio
Posted: Sun Mar 06, 2016 1:20 pm    Post subject: BG1209s High Voltage gone?
Last week the pj worked fine, yesterday turned it on but didn't hear the normal crackle and pops. The rear end of the tubes are glowing orange but I don't get any picture. No adjustment screens, where do I look next? Thx Studio
the dude
Posted: Sun Mar 06, 2016 1:26 pm    Post subject:
Look at the EHT board, is the red EHT Hold down LED on? It may be a scan fail, check if the red scanfail LED on the G2 board is on.
Also there is a fuse on the EHT, it may be blown. On newer EHT there is a second LED, if that is on also you may have a broken quad or splitter.
studio
Posted: Sun Mar 06, 2016 2:12 pm    Post subject:
Didn't find any EHT LEDs on, but the red Scanfail on G2 is on.
Posted: Sun Mar 06, 2016 3:40 pm    Post subject:
OK, then your vertical or horizontal or power supply board is bad, causing the scan fail light to come on. With the SF light on, you won't get any HV as the set protects the tubes from burn. You can buy all three boards outright for cheap from me, or send me all three for testing/repair/replacement if you want.
studio
Posted: Sun Mar 06, 2016 11:56 pm    Post subject:
Maybe the problem? Didn't find any fuses blown.
http://i1041.photobucket.com/albums/b419/studio74063/image24.jpg
http://i1041.photobucket.com/albums/b419/studio74063/image32.jpg
Posted: Mon Mar 07, 2016 12:46 am    Post subject:
No, cracks in the g2 block are pretty normal.
studio
Posted: Mon Mar 07, 2016 1:22 am    Post subject:
Which 3 boards, about how much?
Here is a list of the boards that are installed.
R762719 RGB INPUT & SWITCH
R7621055 RGB ANALOG AUTO SYNC INPUT
R762720 RGB GAIN CONTROL
R762839 RGB OUTPUT AMP
R7628162 CRT UNIT RED
R7635725 CRT UNIT GREEN
R7635726 CRT UNIT BLUE
R7625115 CONTROLLER (ASIC) rwiV5.10 ctrl#1209V7.14
R762457 DEFLECTION SWITCHING
R7621127 SYNC & VERTICAL DEFLECTION
R7621127S SUB UNIT V HOLD
R7621085 HORIZONTAL DEFLECTION
R7621085S
R769057 MAGNETIC FOCUS & HOR. SHIFT
R769057S SUB UNIT VH/P
R762518 CONVERGENCE DRIVER
R762519 CONVERNCE OUTPUT
R762514 DYNAMIC ASTIGMATISM
R769021 SM MODE POWER SUPPLY
R769021S SUN UNIT STBY
R762284 POWER INPUT
R762716 EHT
R762833 QUADRUPLER
R762718 SPLITTER
R769056 SM POWER SUPPLY 2 + G2
R762120S FOCUS VOLTAGE STABILIZER
Posted: Mon Mar 07, 2016 2:20 am    Post subject:
Email me please at curtpalme at shaw.ca
thanks!
