fragzero
| Posted: Thu Feb 25, 2016 11:20 am Post subject: Back to CRT - BD808s raster Setup question |
Situation
BD808s P16 blue/red PT18 Green. HD117-24 lenses.
I stumbled upon this projector + spares + HDFury cheap so I'm back in the CRT game. Right now it's up on the ceiling, still have to square it to the screen. Now I have a question which I have always had and can't seem to figure out.
How do I make sure the rasters are setup correct? Right now I can see the top and bottom of the raster but not the sides. Using installation I can move the raster and see the sides (at the very end of the correction-range so 10 and 90 left/right)
Is it ok like this? Do I need to tweak the raster? I could reduce the size by using the master width trimpot on the SMPS sub board.
Curt writes:
Go into the geometry menu and set the H width to 50%. Put up the test grid (genlocked test pattern) and set this trimpot so that the test pattern _just_ overshoots the sides of the tubes
I checked this and that's exactly how it has been setup.
Do I need to change anything?
