JayAllan
| Posted: Tue Feb 02, 2016 11:24 pm Post subject: What model(s) are the cheapest good used 4k JVC Projectors? |
I am running a JVC RS1 now in my bedroom. I am happy with the picture quality (not as good as my crt but not bad) and I am wondering if there is an inexpensive path to upgrade to TRUE 4k in the used market. Perhaps Sony as well.
nettwerkjohn
Joined: 08 Mar 2006 Posts: 921 Location: Blenheim, Marlborough, New Zealand
| Posted: Tue Feb 02, 2016 11:54 pm Post subject: |
If you want true 4k the only domestic option is the sony.
The jvc 4k is interpolated. X900 series and before won't accept a 4k signal from bluray.
Having said that, I am more than happy with the x900. Pixels are invisible, even right at the screen.
Very nice, bright, smooth picture. I'd buy another one.
| Posted: Wed Feb 03, 2016 12:26 am Post subject: |
Jay, I'd really wait a couple of years. I personally wouldn't want anything first generation, and finding a used 4K anything right now really is expecting a bit much. They only came out 2 years ago..
| Posted: Wed Feb 03, 2016 4:47 am Post subject: |
Unfortunately as has been mentioned, true 4k is only Sony at the moment. There is also 3chip DLP, but that is even more expensive. If you don't need true 4k, then JVCs eshift is the next best thing. Why are you looking?
JayAllan
| Posted: Wed Feb 03, 2016 6:14 am Post subject: |
Thanks guys. I didn't realize the JVC was not real 4k or UHD. I am looking at the new UHD Bluray players and reading about the expanded color gamut and dynamic range. It got me thinking if there were older models for cheap I would pick one up just to play with it although it sounds like that is not the case.
JayAllan
| Posted: Wed Feb 03, 2016 6:15 am Post subject: |
| nettwerkjohn wrote: | If you want true 4k the only domestic option is the sony.
Very nice, bright, smooth picture. I'd buy another one. |
Would it accept the signal with a 4k HDFURY?
kal Forum Administrator
| Posted: Wed Feb 03, 2016 3:18 pm Post subject: Re: What model(s) are the cheapest good used 4k JVC Projecto |
| kal wrote: | | JayAllan wrote: | I am wondering if there is an inexpensive path to upgrade to TRUE 4k in the used market. |
4K is the bleeding edge of technology at the moment so words like "4K" and "inexpensive" do not go together.
Kal | Depends on your psychosis, eh?
| Posted: Wed Feb 03, 2016 5:47 pm Post subject: |
| JayAllan wrote: | | Thanks guys. I didn't realize the JVC was not real 4k or UHD. I am looking at the new UHD Bluray players and reading about the expanded color gamut and dynamic range. It got me thinking if there were older models for cheap I would pick one up just to play with it although it sounds like that is not the case. |
Right now, the only reasonable option is the JVC. The new ones will accept and display the new HDMI spec. A RS400 will set you back about $3500.
One thing about UHD is there isn't a lot of content yet. I can see it taking till the end of the year to get a number of titles.
A Fury might be able to pass the signal, but most older pjs won't be able to display the expanded color gamut.
JayAllan
| Posted: Fri Feb 05, 2016 7:25 pm Post subject: |
It is mostly the expanded color gamut that I am interested in. I suppose I will have to wait
| Posted: Fri Feb 05, 2016 7:33 pm Post subject: |
If you want an expanded color gamut pj, then you could look for LED DLPs. I think some of them are starting to drop down to reasonable prices. I am not sure a Fury could get you Rec2020 with one or not playing UHD.
| Posted: Fri Feb 05, 2016 9:57 pm Post subject: |
So the rainbows will look more colorful?
JayAllan
| Posted: Wed Feb 10, 2016 6:21 pm Post subject: |
| Spanky Ham wrote: | | If you want an expanded color gamut pj, then you could look for LED DLPs. I think some of them are starting to drop down to reasonable prices. I am not sure a Fury could get you Rec2020 with one or not playing UHD. |
I will have to look into that. In the meantime I guess I will just get a new bulb for my RS1 and continue to enjoy it
