centering Problem with XG 135
super-digger
Posted: Wed Jan 27, 2016 6:14 pm    Post subject: centering Problem with XG 135
Anyone here who can help on a Problem with a NEC XG 135?
The Problem is that the Grid and the picture is not in center.
We have try to make a perfect Hardware Setup and the Offset is perfect but it is not posible to slide the vertical Testgrid and picture to the Center.
So,where is the mistake that we make.
Best wishes from Germany
there are no Proplems , only challenges
Posted: Wed Jan 27, 2016 6:50 pm    Post subject:
Have you been in the service menu area? Raster centering is only accessible from the serivice menu (set up a passcode), and is set fully digitally unlike prior NEC projectors.
The proper method for centering: Set the brightnes so the raster light up on the tube face (leave all blankings full open) center the raster on each tube against the tube edges (looking directly into the tubes, you should lower the contrast to not get blind Wink).
Once the raster is centered on the tube, center the actual image with the "position" menu, then use "Phase" to center the test pattern on the center of your actual image. This is an important step because all other convergence adjustment referenced to the center of the cross hatch pattern.
Posted: Wed Jan 27, 2016 7:05 pm    Post subject:
^excellent advice! Smile
super-digger
Posted: Tue Feb 02, 2016 12:26 pm    Post subject:
Thanks for your help,
Today I wil try to make the setup complete.
It is for a friend my own projector is a G70 from Sony.
The service menue can be entered after setting password, or generally?
Which menu point is for the sliding the cross
Posted: Tue Feb 02, 2016 4:26 pm    Post subject:
You have to setup a password, with that you'll have access to the service menu, BTW 3151 is the master code, that do it too.
The "Phase" button on the remote does the test pattern centering, you'll also see a hump on the horizontal line that is the center of the "point convergence", that hump can be moved by pressing CTL + arrows (only left / right)
Jeremy112
Posted: Tue Feb 02, 2016 4:38 pm    Post subject:
I just use the 3151 as gjaky mentioned, never bothered to set a password up (too hard to remember all the damn things anyway, why would I want to remember a different one for a projector? Razz )
Great advice gjaky Thumbs Up The XG is a lean machine Very Happy
Posted: Tue Feb 02, 2016 4:49 pm    Post subject:
I use also the 3151 exclusively, but if the passcode is disabled you can't access service menu at all, so in the end you'll be forced to set up a password and it can't be 3151 Razz
Jeremy112
Posted: Tue Feb 02, 2016 6:10 pm    Post subject:
Good point Wink
super-digger
Posted: Sat Feb 20, 2016 5:30 pm    Post subject:
We have just try to complete the Settings.
Now we have activate the HTMI V1.3 Card an the picture with the Card is Bad !
The raisin of the Gama has no Effekt
The Probleme with the centring is a Little bit better (course Center is up to 100 percent).
super-digger
Posted: Sat Feb 20, 2016 5:34 pm    Post subject: Problem with nec xg
Some photos of the Projektor
Posted: Sat Feb 20, 2016 6:29 pm    Post subject:
I don't see any pictures
super-digger
Posted: Thu Feb 25, 2016 7:23 am    Post subject:
Second try!
We have try to change the Gama and Contrast on the HDMI Card with the Remote and the Little screws, but with no Effekt.
Nec Projektor
 Filesize:  95.27 KB
 Viewed:  6391 Time(s)
