Request dot pattern png
redfox001
Posted: Fri Jan 22, 2016 10:04 am    Post subject: Request dot pattern png
Hi is there someone that can make a dot pattern for focus and astig in 1080p png format? I have a mac and need to boot to windows to use the nokia nec patterns. I have all the other patterns available even smpte but in all the time I have never found a dot pattern. So if you have one I would be very gratefull!
redfox001
Posted: Fri Jan 22, 2016 10:24 am    Post subject:
Well I should ask more and than google this Smile But it is not a png.
http://www.aaarpinball.com/Miscellaneous/p1080.htm
barclay66
Posted: Fri Jan 22, 2016 11:07 am    Post subject:
Maybe this could be of help...
Regards,
barclay66
Test_PNG.zip
 Filename:  Test_PNG.zip
 Filesize:  111.14 KB
 Downloaded:  261 Time(s)
redfox001
Posted: Fri Jan 22, 2016 1:37 pm    Post subject:
Wow! Those are great testpatterns. Thanks thanks thanks!
