What equipment do I need?
larryp
Posted: Tue Dec 22, 2015 9:52 pm    Post subject: What equipment do I need?
I have a sony projector (1272) and am using the Sony switcher with rgbvh connectors.
I am canceling my Direct tv.
Besides a antenna, What do I need to buy to get local stations? It will have to run thru the switcher.
Advice appreciated. Thank you.
Merry Christmas to!!
Posted: Tue Dec 22, 2015 10:01 pm    Post subject:
AN over the air tuner box like this: http://www.amazon.com/Mediasonic-HW-150PVR-HomeWorx-Converter-Recording/dp/B00I2ZBD1U/ref=sr_1_5?ie=UTF8&qid=1450821552&sr=8-5&keywords=mediasonic&tag=curtpalmecrtp-20
This one you can plug a USB hard drive into and record your shows.
You'll need a way to get from Component to RGBHV like a transcoder or from HDMI to RGBHV like an HDFury.
Have a look here to see what's what with the over the air stuff: http://antennaweb.org/Info/Resources.aspx
larryp
Posted: Tue Dec 22, 2015 10:32 pm    Post subject:
Do they make a tuner box that accepts a rgbvh break out cable?
Posted: Tue Dec 22, 2015 10:34 pm    Post subject:
I doubt it. Nobody but us antique-collectors uses RGBHV any more. Laughing That's why we have HDMI -> RGBHV converter boxes.
Posted: Wed Dec 23, 2015 2:07 am    Post subject:
no but an HD Fury , the new nano, is only $89.
Even cheaper HDMI converters on flea-bay if you want experiment with a " mystery box" .
This is what I would do, component is obsolete and by putting an HDMI splitter before the Fury you can have your BD player, and a slew of other HDMI sources all trans-coded by the Fury.
larryp
Posted: Wed Dec 23, 2015 4:33 am    Post subject:
All I want to do is watch local channels, I don't record anything. I have a moome HDMI card in the switcher but it's 2 outputs are in use
Posted: Wed Dec 23, 2015 12:16 pm    Post subject:
Kworld made a tuner with VGA out. Careful when you're looking though, there are two versions, the other one is DVI/HDMI.
Alternatively you could just add an HDMI switch to one of those inputs on your Moome card and order the box I linked to up top.
