Video-noise on red LUG Cine 9
Hulio
Posted: Fri Dec 18, 2015 11:32 am    Post subject: Video-noise on red LUG Cine 9
The red tube on my Cine 9 shows same noise on higher pixelclock. No problems with 1080i@72 or 1080p@60. Only with 1080p@72 (178MHz pixelclock, according to Crystalio II menu), on both ports 3 and 5.
I already swap every board possible including neckboard and controller, with the same result. Because the problem is on red only, i suspect a tube issue.... Anny ideas ?
Here two pics of the tube in question, first at 1080p@72 and second at 1080p@60.
redfox001
Posted: Fri Dec 18, 2015 12:03 pm    Post subject:
I once had blue noise little picks but that urned out to be hdmi noise. Bad cable or oxidised connector if I remember well. You could try a low resolution or internal testpatterns for that. Oh wait you only have it on higher pixelclock so that confirms this possibility.
I use Brasso to clean connectors. Leave them in for 30 minutes or so.
dummyload
Posted: Fri Dec 18, 2015 12:12 pm    Post subject:
Hey Hulio
Swap green or blue bnc on port5 with red and see if noise go to other tube , then you know is source or tube issue.
Hulio
Posted: Fri Dec 18, 2015 12:57 pm    Post subject:
Aha, i knew you guys are clever here. Yup, swapping the red and green bnc's on port 5 moved the problem to the green tube. Thanks Dummyload and Fox for the tips.
I knew is not source related ( same noise from Oppo, PS3 and Popcorn Hour ) and not a cable issue either ( tried four differend well-known brands, even very short one ).
Can be the mainboard ? Even with Moome internal Full HD on port 3 i have the issue. I am glad i don't have to buy another tube but thinking about how much work is needed to swap the mainboard, i kinda wish it was the tube Very Happy
Hulio
Posted: Fri Dec 18, 2015 1:58 pm    Post subject:
Wait a minute, can't be the mainboard neither. It is the damn Crystalio II with bad red output stage. I changed my sources each time but they all go trough the same videoprocessor. I will try all in-and outputs on the Crystalio first. The thing is, without a scaller, no way i can feed the Barco @72Hz.
redfox001
Posted: Fri Dec 18, 2015 4:27 pm    Post subject:
He Hulio check the hdmi inputs. Good change one pin is corroded. I used a "kwastje" with brasso and let it work 15 minutes.
Hulio
Posted: Fri Dec 18, 2015 5:18 pm    Post subject:
Thanks Fox, i'll do that and report back. I think my wife has that kind of copper-polish thing.
Hulio
Posted: Fri Dec 18, 2015 9:52 pm    Post subject:
Well, no luck with cleaning the inputs and outputs. Still the same "snow" in red channel @72Hz. I think i give up on the scaler. The main reason i use it it's because of 72Hz output and porch settings. The timings from Oppo BDP-103 seems to be ok, so i'll stay with 1080p@60.
Posted: Fri Dec 18, 2015 10:02 pm    Post subject:
Stay with the 72Hz on the scaler, but alter the timings somewhat, what happens? Can you push the resolution even further?
Hulio
Posted: Fri Dec 18, 2015 10:35 pm    Post subject:
I will try that tomorrow Gabor, thanks for the heads-up. With the Crystalio's standard timings for 1080p@72 i end up with a pixelclock of 178MHz. A bit too high, i think. But why noise in one color only ?
redfox001
Posted: Fri Dec 18, 2015 11:17 pm    Post subject:
You tried other hdmi input on the moome?
Hulio
Posted: Sat Dec 19, 2015 8:01 am    Post subject:
Yeah, i tried all four inputs on the internal Moome with the same result. I have the same issue on port 5 with a HDFury III so must be that the Crystalio can't handle a pixelclock higher than 160MHz. Later i will try some custom resolutions, like Gjaky sugested, lowering the pixelclock while still outputing @72Hz.
Long time ago, when Crystalio was still supported, Henry from "CRT projectors.co.uk" posted custom timings that worked with Cine 9, but i can' find them anymore.
nidi
Posted: Sat Dec 19, 2015 11:34 pm    Post subject:
not all Crysalio II's behave the same.
it's definately the pixelclock that is too high.
Pixelmagic once told me that it will behave strangely above 160 MHz pixelclock, especially when it has run fora while.
It's a shame that they never released the Crysalio III , where very far in development.
use a Lumagen XS+ for higher pixelclocks, they selected chips that can handle the higher frequency.
btw, I still use the C2 for SD content, as it still produces the best picture!
Michael
lydmann
Posted: Sun Dec 20, 2015 11:27 am    Post subject:
yepp, this is typical for a bad kabel which not managed the high pixelclock. buy a fiber kabel and you are fine, i did, and problem went away.
ElTopo
Posted: Sun Dec 20, 2015 11:40 am    Post subject:
Could you please post a link where to buy such a cable ?
Barco Cine 9 the one and only
redfox001
Posted: Sun Dec 20, 2015 2:18 pm    Post subject:
Yes I have a Macbook pro without hdmi so I needed a displayport to hdmi cable and that one gave the same problems and would not go past 1080p@60. Than I found the club-3d cable for the Macbook pro and that one still works fine at 1080p@72. So for the Mac users with older material try this one:
http://www.club-3d.com/insights/thread/cac-1153-and-macbook-pro/
Posted: Sun Dec 20, 2015 2:59 pm    Post subject:
Michael
If you still have the noise when connecting the VP to the Moome with a 6' HDMI cable than it is most likely the VP, but it is slightly possible that it's the Moome card (though not if you are seeing this with your HDFury as well). Try a short standard quality 6' cable, no boutique cable manufacturers. Use Monoprice, Bluejeans, or something basic for the cable.
This is absolutly digital noise and is not in your analog section,
Hulio
Posted: Sun Dec 20, 2015 9:22 pm    Post subject:
Thanks for helping me out, guys.
Yes Craig, i also think it's the VP. I won't blame the Moome card, same sympthoms with Fury III on port 5 indeed. Already tried a 2m long Monster M1000HD cable with no go.
About fiber cables i don't know. I suppose they need a kind of driver too, you just can't use them like that. Plus, i do not want to spend again in cables to find out is still the VP faut.
I'll try to overwrite Crystalio's firmware with the same version too ( some folks reported improvements in older posts ).
Posted: Sun Dec 20, 2015 11:54 pm    Post subject:
Don't use the Monster cable. Their HDMI cables are absolutely terrible. Test with a standard quality 6' HDMI cable from the VP to the input card to know for sure.
Hulio
Posted: Mon Dec 21, 2015 6:31 am    Post subject:
Craig, when testing on port 5, i swaped the red and green BNC cables ( like Dummyload sugested ) and the video-noise moved to the green channel. Would that not rule out a cable issue ?
