Willem Programmer G90 Dallas Chip woes
Alan Head
Posted: Sat Nov 21, 2015 8:43 pm    Post subject: Willem Programmer G90 Dallas Chip woes
Plea for Help,
It's about 8 years since I replaced the Dallas Chip in my YA Board.
In this time my PC has been upgraded several times so I am not sure the exact hardware configuration I had 8 years ago.
I decided it was time to make a backup of the chip "Just in Case".
I found one of my old PC's with a parallel port and set it up with the Willem Programmer and software as before. Its Running Win XP media center edition. It has a dual core Athlon 64 X2 Dual Core 3800+ processor.
I made a copy of my current Dallas chip and saved it.
I thought I would try to write it to my original Dallas Chip to ensure everything was OK.
This where things get strange. I am able to write the data to the old chip but it fails at 12% when verifying.
I took the Dallas chip from my spares machine and copied it as well.
The Data from my spares machine writes perfectly to my old chip and verifies 100%.
I then tried to write my old data from 2008 when I last changed the Dallas chip.
Now this data appears to write but fails verification immediately. Reading the Dallas chip now contains garbage.
I write all zeros everything works fine. I write all "FF" everything works fine. I write my spare machine Dallas data chip, writes perfectly. I write my recent Dallas Data verification fails at 12%. I write my 2008 Dallas Data and verification fails at 0%. Write my spares machine Dallas chip, all works fine again.
I am going around in circles.
I have changed parallel port address, I have forced the software to run on a single core. Still no change
The only conclusion I can reach is that I cannot trust my programmer.
Anyone experienced similar issues?
thanks
Alan
Posted: Sun Nov 22, 2015 6:35 pm    Post subject:
Alan, what's the power supply for your programmer? That might be the issue.
Alan Head
Posted: Sun Nov 22, 2015 11:32 pm    Post subject:
Craig,
I thought that might be the issue as well.
It is powered via USB. I have tried different USB ports and also an iPhone charger and an iPad charger.
I even tried it in a VMware virtual machine running windows Xp pro. This made it take a lot longer to read and write but the results were exactly the same. I also reconfigured the board and used different software. Exactly the same results.
I am beginning to wonder if it's something to do with the parallel port on my PC motherboard. I'm assuming it's perfectly capable of reading accurately and only has a write issue. I'll try to find an old machine at work and give it a go next weekend.
It defies logic, I could understand if it wrote nothing successfully. However as long as the image was read on this PC it will happily write it.
Alan
Alan Head
Posted: Thu Nov 26, 2015 5:52 pm    Post subject:
Problem Solved !
I gave in and purchased a MiniPRO USB programmer.
Reads writes and verifies all my old images.
I guess the printer port on my old pc was not sending a reliable voltage when writing.
I have heard of others adding pull up resistors to get these parallel port programmers working.
I now have a programmer that programs extremely quickly and works in Windows 8.
Alan
