Help, green tube offf
crt nuts
Posted: Thu Nov 12, 2015 2:52 am    Post subject: Help, green tube offf
Hello all
Its been a long time since I've had the time to enjoy my crt PJ . Bought Star Wars and thought I would sit down with some popcorn and watch the first disc. Did not get 10 min into the Phantom Menace and the green tube goes dark.
@1500 hrs that seems premature, on these frankenyoke tubes,. Can anyone provide some clues as to what might be the cause.
Thanks very much
Nuts Sad
All that glitters is not gold thats why I prefer red, green and blue.
Posted: Thu Nov 12, 2015 3:00 am    Post subject:
A make and model would help!
Posted: Thu Nov 12, 2015 4:13 am    Post subject:
CRTnuts you're running a Vision1 aren't you?
crt nuts
Posted: Fri Nov 13, 2015 12:57 am    Post subject:
Oh sorry. I'm mt headed at the best of times..... Embarassed yep Vision 1 with the frankenyokes.
I was about to take the covers off and remembered that I should listen to the wise men first.
Laughing
Posted: Fri Nov 13, 2015 1:06 am    Post subject:
First off, do the test patterns show green? If not, then proceed with:
-check the filament voltage to make sure it's still at under 6.5 volts. the 2 pin P14 connector is at the back of the blue tube. Measure that with a voltmeter.
If that's OK, then you have a video output board, VIM board or video connector issue.
Make sure the tube filament is glowing orange through the back of the neck board, where you can see the CRT socket.
Swap the CRT neck boards between tubes, making sure that the white wire is connected to the right pin before you power back up. Swap the green and red CRT sockets. Does the red tube now stay off, and the green come on?
crt nuts
Posted: Fri Nov 13, 2015 2:25 am    Post subject:
I have checked the filament voltage in the past and was rock solid below 6.5v . Would that change during the life of the tubes?
I wondered whether gravity was creating connection issues and will check out all possibilities as you suggest.
Will post back tomorrow, thanking you for your kindness
MG Thumbs Up
Posted: Fri Nov 13, 2015 2:51 am    Post subject:
it can if the LVPS was mis-manufactured. It's good to check it regardless if you don't know if it's an Ultra supply.
crt nuts
Posted: Sun Nov 15, 2015 3:30 pm    Post subject:
Pulled the covers off from the V 1 and turned on to check that there was life on the neck board end. All crts lit and stayed lit for the next 4 hrs. Watched more Star Wars and some youtube videos.
Cannot reproduce the failure but will bring my multimeter home to measure filament voltage again. maybe its time for some upgrades. This machine has MP's earlier neckboard mods and also IIRC the VIM input card, but these are now at least 7 years old.
Sad . I realise I need to pay to play so its time to save for the hobby again. We will be stuck indoors soon and need to keep the theatre up to spec.....
Thanks guys
MG
