NEC PG9 does strange things
tschaeikaei
Posted: Sat Oct 17, 2015 6:15 pm    Post subject: NEC PG9 does strange things
Does anyone have a hint on this? I already changed the big deflection board, but no improvement.
Projecting a black picture, photographed directly onto the tube face. The green looks the same.
Now with some window on the screen. The red tube is dim because my VGA-BNC cable has a loose contact.
Don't worry about that, using another cable doesn't have an effect on the pic.
Regards, Julian
Posted: Sat Oct 17, 2015 7:17 pm    Post subject:
The first question regarding the plain PG always have tobe: are the capacitors still original in the machine?
-If yes, then -unfortunately- you most have to replace A L L the 300+ capacitors in the set if you want to ensure further reliable operation from the machine. Because the original capacitors are leaking out for now...
Just for a quick testing however you can try to pull out the POINT PWB to see if it helps for now.
tschaeikaei
Posted: Sat Oct 17, 2015 8:48 pm    Post subject:
Yeah 100 points for gjaki. I switched the point board with another one (before reading the reply) and boom! that works.
Strange thing is: The projector did this image distortion for the last 8 or 9 months everytime i switch it on.
But: After a few minutes of running with distorted picture, i used to switch it off and back on. Usually the pic was normal then.
But how can the point board cause this problem? I thought it might be some strange deflection error.
I think i will replace the caps on the point board (10 caps there) and see if everything runs fine then.
Thing is that i want to sell the PG9 and i want to sell a running pj. Thats why i want to fix this now, didn't bother me in the past,
i had enough to do with the marquees.
Thank you, regards Julian
Posted: Sun Oct 18, 2015 1:10 am    Post subject:
Leaking capacitors cause this on the point board. I've seen this a few times, I never bothered tracing out why, as I don't have the extender cards needed to get the board accessible while it's turned on.
I don't support PGs any more here due to the massive leaking capacitor issues. I have now gotten rid of all parts except for some new old stock tubes.
hansilili
Posted: Mon Oct 19, 2015 10:15 am    Post subject:
I tend to disagree with that part of the quote. I have been lucky with the caps on my NECs so far. But yes, the exact same failure of the point board happened to me too. If you want to recap it, DON'T PULL THE LEGS OF THE OLD CAPS but CUT THEM! I learned it the hard way myself.
CHeers!
redfox001
Posted: Mon Oct 19, 2015 11:14 am    Post subject:
I learned to use desolder wick to completely remove the solder from the legs and than remove. Else you might end up damaging the board.
tschaeikaei
Posted: Mon Oct 19, 2015 7:32 pm    Post subject:
I desoldered two caps (had only two fitting values laying around), it's kind of bugging, but totally doable.
And yes, they were leaking. But the pj runs fine now and since i don't want to really use it myself i won't rip it further apart
just to solder some money and time into it :=)
But thank you guys for the tips.
Rgards, Julian
Posted: Mon Oct 19, 2015 11:01 pm    Post subject:
CHeers!
And we did tell you too Wink
Posted: Mon Oct 19, 2015 11:05 pm    Post subject:
You dont do that on these NEC boards, the best way is to pull the caps off the board leaving the legs behind and solder the new cap to the legs.
Desoldering the legs on these boards is asking for trouble, and now youve all been warned again, but anyone may feel free to think they know better if they really want to Wink
Rattanee
Posted: Thu Oct 22, 2015 8:32 pm    Post subject:
I desoldered every single cap on my first PG9, didn't pull a single trace. Then again I have 20+years of experience with PCB desoldering and a good desoldering station Smile Unfortunately in my case my point board has some other misterious problem... probably a dud RAM.
gregstv
Posted: Thu Oct 22, 2015 8:46 pm    Post subject:
Pre-warming the board before removal and replacement of through hole components makes the process very easy.
Rattanee
Posted: Thu Oct 22, 2015 9:04 pm    Post subject:
Exactly. I don't have a preheater, but a hot air SMD gun in one hand, desoldering iron in other, works flawlessly even for boards with several layers. A hairdryer works in a pinch if it's hot enough.
tschaeikaei
Posted: Fri Oct 23, 2015 9:38 am    Post subject:
It seems to be a problem that occurs often these days. Someone soldered on a motherboard or graphics card?
Crazy sh*t. These multilayer (more than two layers of copper) need so much heat to melt a small solder point,
you will most likely destroy any through-hole part you want to lift off.
So for the NEC, i agree that cutting wires and soldering new parts to the left wires is the easy and safe way.
The other way requires much more heat and effort, but the result looks better.
Too much heat could loosen the copper layer from the substrate.
Question is: do PCBs have to look good?
I think no. And in the future i will just cut legs go the easy way.
Regards, Julian
