G70 - Green tube dead after moving
spacdj
Posted: Tue Oct 13, 2015 3:34 pm    Post subject: G70 - Green tube dead after moving
Hi.
First of all sorry for my poor english.
After moving a G70 from Rome to Bologna (about 4 hour trip) the green tube no longer turns on.
No error code appears.
I suppose some contact has loosen.
Do you have any tip about where most likely is the loosen contact?
I'd really appreciate any help.
Thank you.
Ciao,
Stefano
Posted: Tue Oct 13, 2015 4:17 pm    Post subject: Re: G70 - Green tube dead after moving
check to make sure that the video neck-board on the back of the tube hasn't slid off the back of the CRT socket
http://www.curtpalme.com/SonyG70_Layout4.shtm
tschaeikaei
Posted: Tue Oct 13, 2015 6:12 pm    Post subject:
I've never ad a Sony.
If it's not the neckboard (which seems very likely) is it possible to increase G2 without too much effort on the g70?
Then you should see if HV is provided to the tube.
But... isn't there a forum guy in Rome?
Don't have his name now, but I'm sure someone does.
Regards, Julian
barclay66
Posted: Wed Oct 14, 2015 4:23 am    Post subject:
That's Domenico. Decibel is his forum nick...
Posted: Wed Oct 14, 2015 4:34 am    Post subject:
Dragan is most likely correct. Let us know if that's it.
spacdj
Posted: Wed Oct 14, 2015 8:03 am    Post subject:
Thank you for the answers, that I've forwarded to the guy in Bologna.
Also sent a PM to Decibel (Dragamn is in Colorado... Smile )
Ciao,
Stefano
Posted: Fri Oct 16, 2015 9:43 am    Post subject:
Ciao,
Stefano
No he means DraganM is probably correct in his diagnosis of your issue, in that he believes the green neck board has backed off the neck a bit and is not making good contact.
Decibel
Posted: Fri Oct 16, 2015 11:01 am    Post subject:
Unfortunately I don't know G70's projectors.
Stefano purtroppo non conosco i Sony G70.
Comunque da quello che descrivi sembra proprio un problema di contatto elettrico perduto durante il trasporto.
Le neckboards sono quegli elementi posti alla fine del tubo. Ispeziona i cavi e vedi se ce n'è uno scollegato.
Domenico (Barco fan!)
spacdj
Posted: Fri Oct 16, 2015 11:12 am    Post subject:
Thumbs Up
Ok, thanks
