barco 1209S GR. how to remove Quadupler
offshorecl1
Posted: Fri Oct 02, 2015 5:15 pm    Post subject: barco 1209S GR. how to remove Quadupler
Can somebody help me with;
It's really complicated remove the quadrupler. Asking the forum if there is a quick way to remove the quadrupler?
1 screw downside is easy, but the 2 screws upside? How to reach?
Regards, Jo
Posted: Fri Oct 02, 2015 5:45 pm    Post subject:
ONe screw is under the Ac input board. Unplug the projector, wait 1/2 hour, and then take off the Ac input board. Also take off the white plastic sheet behind the AC input board, and you'll find the second screw. Take that out completely.
The third screw is in the back corner of the projector. You can either drill a hole into the side bottom of the case to access it, or wiggle the quad around to loosen partially that screw once the other two are loose. The quadrupler then slides up and out with the screw still in place. (slides down if the set is ceiling mounted).
When I replace the quads, I do not put the two screws back in, I hold the quad in place with the single screw at the top of the quad.
Posted: Sat Oct 03, 2015 2:04 am    Post subject:
Hammer and a cold chisel will get it out of there.
